  • Replies 158
Posted Images
Updated list of stuff. Probably well over due. There's still plenty more to go; if it's not listed here, just ask.
r32 gts-t shell - $offer!
Engine mounts - $30
Rb20det engine loom $40
Lower dash trim - $20
Door cards $40 for both - passenger door card has a tear near the mirror - easily fixed
Mirror triangle cover thing - $20
dash in good condition some very small bubbles (didn't notice until i found out these things bubbled up) $100
centre console storage thing between the seats $20
centre console surround that the storage thing connects to $20
rear wiper motor $20
passenger door with window and motor (minus door card and mirror) $60
dash cluster surround (minus switches) $40
Passenger side A pillar trim $20
boot trim minus cover for wheel arches and boot carpet $30
Mirrors - $40 each
front windscreen (has small chip - been there for years, no probs) $100
rear windscreen $200
drum brakes (in bits and pieces) $10 for both
tail lights $40 each
rear bar $40 - has one dint and one scratch
passenger side front guard (has slight bend) $20
kick panels - $10 each
Rear callipers $150
Rotors x 4 $100
brake booster $40
3" catback exhaust - straight through muffler and doesn't get attention (looks kinda stock) $100
stock dump pipe to cat including sensors $40
Pod filter $20
AFM $100
hicas rack $40
fuel tank $100
fuel pump $30
Interior carpet $50 - has a tear in the driver's side (probably easy to conceal/fix), otherwise perfect
Centre dome light (without cover) $10
front reading lights $15
roof lining $30
stock crossover pipe including BOV $40
Stock rb20det side mount intercooler $30
rb20 power steering reservoir (minus cap) $15
A/C compressor $20
boot hinges $20
front windscreen wiper motor $40
HICAS computer $30
steering column $40
alternator $5 (not sure of condition - i think a bit of battery acid spilt onto it or some crap, doesn't turn easily)
hazards/tune/wiper switch (headlight switch already gone) $20 each
Passenger side rear quarter trim arm rest thing $20
Stuff that's gone -
hand brake handle/cable
centre vent - $80
driver's side round vent - $40
Driver's side rear quarter trim $20 each
rear wiper arm
dash cluster (218,635kms) $30
indicator stalk $40
Driver's side A pillar trim
glovebox $50
sun visors $20 both
rear vision mirror $20
door seals - driver's side has one crack in it, passenger side perfect $60 both
passenger side quarter window $60
driver's front guard (rooted from accident) - free!
bonnet (rooted from accident) - free!
Front callipers x 2
rb20det $offer!!
starter motor $50
Centre dome light cover
rb20 power steering reservoir cap
Climate control panel $60 - not sure if the lights in it work
bonnet hinges $20
front seats
rear seat
front wiper arms $20 for both
Washer bottle $20
rear pods $70 pair
Stock manual ECU
clutch+gearbox etc for manual conversion (still have flywheel)
passenger seat belt
interior mats
6 x injectors
Trim around the steering column
Turbo
Power Steering Rack
Stock coils
Ignitor
Driver's side door (just the door itself and window/motor mechanism)
Passenger side vent
Headlight switch
centre console tray holder thing
fuel pump cradle. Still have fuel pump
front seat buckles
ash tray
front fuse box fuses/relays/whatever
driver's side window control
diff
b/c pillars
locks/keys
brake master cylinder and 3 brake lines connecting to it.
Driver's side rear quarter window
inside passenger door mirror cover.
Boot lid
side skirts
Black metal intake pipe
Half shafts
fuel filler neck
fuel lines
Fuel flap
power steering pump
wheels/tyres
wheel jack
plastic knob cover for light switch
metal panel between boot and back seat
Metal trim around driver and passenger windows
Coolant temperature sensors
Speedo cable
window washer/wiper knob
alternator tension bracket
hubs/5 stud conversion
Driver's door power window relay
Accelerator pedal and cable
Brackets that attach the stereo in the centre console
bonnet support rod
Consult cable
Front sway bar end links
Stock cat
Passenger window switch
2 x rear seat "JESUS CHRIST!!1" handlebars
Passenger side interior door opener cover
rear demister switch gone!
Suspension x 4
Plug for front driver's side indicator
Heater core
Boot/fuel cap cable
Headlight wiring loom PENDING PAYMENT
Edited by verger
does this come with the thick black pipes/lines that go to paower steering pump?
Nah the piping went with the intercooler.
As for the stereo insert, do you mean the brackets which bolt onto the head unit itself? If so, that's gone too.
Hey there, I don't suppose you have the external metal screw and black body plug for a motorised aerial? Picture included for reference. I don't need the aerial, just the external attachments.
hey mate,
I need the exteranal moulds around the doors, that screw onto and between A and B pillar onto the shell and house the rubber.
please ring or sms me on 0438 600 350 if you have them
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
