Hi D0p3y
Thanks for the thread. After reading it I had to go do it myself. Took the car for a week and just went cruising.
Mate also really appreciated the info you posted as well.
Two thumbs up cant get the grin of my face.
  • Replies 55
Posted Images
Nice one, I am dying to go back. Have been working on plans for a 12 day road trip actually, but probably won't do it until December next year (I want to do Nismo Festival again, hopefully they resume next year)
Is the GT-R still the same white 2007 model that I had?
Ah, thanks. I was hoping they had a fresher car by now -- the car I drove had 70k on it too and it was starting to feel a bit clunky. But, more importantly, I want to drive the updated model to see how much it has improved since.
Hmm, it was a while ago now but I can't recall it doing it badly. The whole car did feel like it had been thrashed hard though.
Damn... all this talk makes me really want to go back ASAP
LOL I'm still in Japan and I don't want to come back.
I got the same impression with the car that it had had a hard life.
Have had some epic runs/cruses with some great people in some really serious cars.
Whereabouts in Japan are you?
  • 3 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
