I have been in the process of upgrading the whole exhaust
removed the turbos and all the gear to replace the dump pipes,
Reassembled everything, then disconnected the battery to tack a few parts of the exhaust underneath the car with a TIG.
Now its all going, only thing changed is the exhaust(all of it), but the engine is running richer than ever before, like 13.0:1 @2000rpm in the shed, and as you back off to get closer to idle, it goes off the scales rich and obviously dies.>_<
Looked at AFM voltages, they are;
ENGINE NOT RUNNING
AFM-1 --- 0.44
AFM-2 --- 0.50
ENGINE @ 1500rpm
AFM-1 --- 1.60
AFM-2 --- 0.75
I removed the afm's cleaned them out and removed the cover from the top, checked the solder joins, they look good, they were new AFM's not long ago..
reassembled and checked again,
same results,
removed AFM's and swapped top one for bottom,
same results, and the voltages stay as is/similar.
I'll take a video and see if that helps too
any help appreciated
Edited by blue_vl_t
https://www.sau.com.au/forums/topic/383599-strange-mapping-problem/
Intake leak will cause the car to run rich as hell, you have measured air coming in and being given fuel for but lost before it gets to the engine. I forgot one tiny vacuum hose, it was enough to make my car idle with black smoke coming from the back. Check every single silicone connector, hose, seal, everything which helps the air stay in the intake.
Edited by SargeRX8
well i had looked a few times,
but i shoved some air in the intake this time and blocked the other, and what do you know, one air leak, i'll fix that, hopefully its all the problem is.
not sure why i always think a problem is something more complicated......
fixed the intake leak, but its running just as bad, like so bad i cant keep it running unless using 1500+rpm, took it for a drive around the block, stalled like 4 times, af mixtures are just going crazy, all over the place.
it will most likely be something simple, a matter of finding it....
ecu is PFC pro, z32 afm's
o2 sensors are removed and bunged up, also turned off on the PFC.
The wiring to the rear AFM is only just long enough to reach, so wouldn't reach the front one.
Im just making up some caps for where the afm connect to the pipework, see if there is anymore leaks, pressurize the system
Just pressurized the system with 5-10psi, looped the rocker cover breathers together, so it pressurized the whole motor, sump and all, its dead silent, no leaks, until the dipstick pops out, lol
so intake leaks, none.
I'll have to see about metering out the afm cables to the ECU, see what i come up with.
I recently had a similar problem with a Z32 that was meant to work..
I have a strange suspicion the body earth for that one is sensitive and may give a crazy effect... Mine was idling at 3.7v, yet i suspect the AFM will work fine when put into a known working case (will test tomorrow).
when using map tracer, in the shed, free revving the engine, if you hold the rpm at 2000rpm and gradually lift the throttle from the floor, the below lovely ms paint diagram shows approximately the path of the map tracer, ie which cells are being used.
Edited by blue_vl_t
blow off valves hooked up and working?
though you did pressurize the intake...
well, i haven't touched them, the car was running fine about a week ago, just removed exhaust side and reassemble with new exhaust.
as you said, pressurized intake, nothing was leaking......
Stock gtr BOV's
Edited by blue_vl_t
a prize.......
i'll take you for a spin, you live close by to Kalgoorlie, lol
I actually could not find anything wrong with the wiring, and i'm an electrician.
but the plugs on the r32/r33 model is quite crap in design, you have to push the plug in further the the bolt will pull it in.
but i recon it is was just a matter of unplug the ecu and plug it in, kinda thing. lol
I do think i will have to install another muffler, the 4" is kinda loud, i am only able to find the Magnaflow ones off the shelf, anyone know if they will do much, or someone to build one custom etc??
it should do, but my crappy superwizz turboteh bleed valve has a stripped thread, loose connection, which is probably why it was running more boost than i thought it was, i removed it, and its now running a massive 12psi, woo hoo.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
