2012 Annual Ben Simpson Memorial Cruise
OLDS
 Share
THE 2012 ANNUAL BEN SIMPSON MEMORIAL CRUISE
28th JANUARY 2012 (Single Day Event)
This Megacruise is in memory of all those who are no longer with us.
If you have lost a family member or friend or just want to join this exceptionally special event you are welcome
STAGEA REPRESENTATION REQUIRED (PLEASE !!!!)
However, all ages, makes & models are welcome, invite your friends it is a wonderful cause & awesome cruise.
Meeting place is WESTFIELD SHOPPING CENTRE - WEST LAKES
Meeting time is from 6.30pm for a 7.30pm start
Memorial Ribbons: If you are cruising in memory of someone please tie a ribbon (their favourite colour) to your ride
Teddy Bears: Our late son Ben loved them...so at each cruise we ask you (if you wish to) to carry Teddy on an empty seat in your car, in his memory
CAUSE: Compassionate Friends - Worldwide Organisation - SA Branch - Parents who have lost their own kids...helping other parents who have just lost a child
DONATION: Gold coin per person or $5 per car
CRUISE LENGTH: Approx 3hrs
Members from SAPOL's Traffic Operations Section will be in attendence. Any anti-social, hoon like behaviour will NOT be tolerated by the organisers or SAPOL.
Is this an "import" only cruise or are the muscle cars allowed to come too?
ABSOLUTELY NOT import only, it attracts all makes and models,"MUSCLE" is most welcome !
the OLD Fella
Oif I still have the stagea I'll bring that. If not I'll bring the chev out and make some noise :)
Mate please bring the Chevy...providing you can afford the petrol for a
3hr cruise...reasonably paced though...gotta be with that many cars
Mark
It's actually not that horrendous. 15l/100km on the way home.
Pretty good considering it ways 2.5 ton and is powered by the most uneconomical V8, but god I love the noise it makes.
Will make it to the start point at the least, might follow up at the very rear depending on how the kids behave themselves :)
Mate (thank you) the cruise will be heading south for the first 50%...so it should work out OK for you
the OLD Fella
PS you wont be the only different ride there....this was well after the cruise was over last year (but the best pic)
IMG_2229.jpg[/img]
...this was from the cruise route
IMG_1950.jpg[/img]
...SAPOL blocked Anzac & Greenhill to allow all the cruise cars through..it was a real buzz lol
Hey Mark, how do you get on with the cops?
I have no intentions of doing anything stupid, however I don't really need a defect station going over my car with a fine tooth comb...
If that's all good, then I might be tempted out, depending on work.
We have an exceptional relationship with them...they are coming to our home to plan the cruise.
Last year we had 700 cars and 5 defects for VERY obvious things (that is not too bad considering 80% were imports).
The same guys will be running it next yr....they operational stratergy is maximum saturation...min intervention.
No guarantees can be given but these guys escorted us last yr...so hopefully all will be good.
O'Mark
  • 1 month later...
I am sure I will be there again - was an amazing cruise earlier this year!
Are you dealing with Stuart McLean? SAU:SA as a club are developing a good relationship with him too.
Indeed we are...he has delegated it to(his deputy) Snr Sgt Lapworth will be OIC on the day...he ran it for us last year
and it was awesome. Yes they are trying very hard to re-build the previously shattered relationship
Mark
 Share
    • From now on read it as minus 5 and minus 7 instead of dash, and you're correct...
    • Opened up the cluster to inspect the gauge itself for signs of damage and it looks good. Got curious since that needle doesn't go back to a "neutral" position by itself (it stays in the same position when ignition is off. so I manually moved it to 1/2. Connected it back, turned on the ignition and the needle started moving up! Not sure what's up with that but before that the needle was way down below empty like fully south west. There's always a chance that the needle moved slightly the first time I tried and I didn't notice because of how slowly it moves and how far it was from the markings. I don't know if the current needle position is accurate so I'll fill it up and see where that brings it. I guess I'll try to adjust it manually if it doesn't get to F. Looks like the needle position is relative and not absolute? Thanks all for your help and patience!
    • You're confusing two different responders and more than one issue. The stock Neo ECU boost sensor is used by the ECU for protection purposes. It is essentially only an overboost sensor. It is not used for determining engine load for fuelling or ignition purposes. That task falls solely to the AFM. Any aftermarket ECU that either has an onboard MAP sensor or a plug in one, will use the MAP sensor as the primary load sensor. Or I should perhaps say "can", rather than "will", because some of them have the option of using other primary load sensors. That MAP sensor is not for the same function as the stock Neo boost sensor. The reason I recommended against a plug and play ECU is that they are intended to run a particular engine and usually in the car that the particular engine came in. So, if you have a transplanted engine in a different car, with some parts of the original missing (such as the boost sensor, for example) and therefore likely non-standardness of the loom and its insertion into the car's loom, then it is very likely that you will run into the same problems with needing to fix up wiring to make it work that you would with the stock ECU. And, if doing so for the stock ECU is enough of an obstacle that you start considering a standalone plugin as a solution, it should become clear that the plugin is quite possibly not the solution you'd hope it to be. It would just lead to more of the same type of problem solving work to get it going. In the above paragraph and in my earlier post, the lack of the boost sensor is not critical. It was just used as an example of something that we knew you did not have right, such that the stock ECU would not work. I took that as an indicator of a reasonable probability that there were other related problems hiding there.
    • I can think of two places in my city of <1.5million population that specialise in automotive instrument repairs.Unless you're out in the wilds of Quebec, you have 3 major Canadian and 3 major US cities within the same distance as the single nearest city to mine. Surely there is somewhere you could send it.
    • I never cared for twins but whenever these conversations came up, I always presumed the higher number represented a larger turbo. Learn something new everyday.
