S A U N S W - Texi, Sos, 12Th February 2012
  • Replies 209
Posted Images
guys i really really want to enter......but im a bit worried about overheating considering im running 17psi boost and like 270rwkw.....and no air flow! anyone had any dramas with this before?
Just to confirm; What do you mean by "no air flow"? Do you mean because there arent long straights for air to get over your radiator?
If you have the standard viscous fan and are worried about heat, leave the car running after each run and the fan will be drawing a large amount of air over the radiator (a shroud is very useful here) after runs. Also you wont be making 270rwkw for the whole course. You're only making that when the boost is right up and your using full throttle. These courses are designed so that you dont have to use full throttle and in many cases it's faster to use less throttle and balance the car so it's ready for the next turn.
If your cooling system is totally stock, you'll be fine. There's regular entrants pushing more than 100rwkw on top of your figure and more boost without issues. Make sure you have the fluid full and no air bubbles in it, then enjoy!
re my lack of license in mail, do you want to do up a form or leave it for the day. Also should I be chasing someone at aasa?
Yeah look I think the best thing to do is to ring AASA and ask, thats going to get a much better result than us worrying about it on the day to be honest (which probably wasnt the best suggestion from me haha), the process is that after the day we send a cheque and all the application forms from the day direct to AASA, they then process them and send the actual license to the applicants direct in the mail.
It's never been an issue in the past, it could be something simple like lost in the mail - who knows! If they have a record of mailing it, tell them it never made it and to please send another. They shouldnt have an issue with that :)
Edit; yep slower is faster, damn right!!! Shame it isnt as fun though :D
Slower being faster I've always found way more fun then just sitting in the middle of a patch of concrete with my foot held down doing skids...
If anyone thinks it's not fun to run a quick time, get in the car with Reece and tell me whats more fun, doing a skid or going balls to the wall...
i used to compete at motorkhana's on dirt when i was young in a datsun 1200. so i kinda know what its about, im not going out there to set times though.....not saying i wont try on a couple of runs, but i want to have fun
Hey guys about the helmets that are in that link, i sent an email to the guy on the central coast and apparently they will not be accepted at eastern creek it does not have a 5 tick aus standards lable or something like that, im trying to find a helmet for the drags/drift at the creek so i can start going but having some troubles getting one online for under $100
Unless you know your EXACT helmet size, you probably shouldn't buy your helmet online anyway... The helmet has to fit you properly with little to no movement for it to do its job.
I'd suggest going down to your local motorbike/motorsports accessories shop and let them know you have a budget, and ask them to help you find a helmet that you like and fits properly.
I got one I use for these days from Sydney City Motorcycles (google for locations near you). They have them all on display and you can try them on. Also prices were clearly marked to save time. Mine is open face, plain black and was about $80 from memory, fine for these days
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
