S A U N S W - Texi, Sos, 12Th February 2012
  • Replies 209
Posted Images
guys i really really want to enter......but im a bit worried about overheating considering im running 17psi boost and like 270rwkw.....and no air flow! anyone had any dramas with this before?
Just to confirm; What do you mean by "no air flow"? Do you mean because there arent long straights for air to get over your radiator?
If you have the standard viscous fan and are worried about heat, leave the car running after each run and the fan will be drawing a large amount of air over the radiator (a shroud is very useful here) after runs. Also you wont be making 270rwkw for the whole course. You're only making that when the boost is right up and your using full throttle. These courses are designed so that you dont have to use full throttle and in many cases it's faster to use less throttle and balance the car so it's ready for the next turn.
If your cooling system is totally stock, you'll be fine. There's regular entrants pushing more than 100rwkw on top of your figure and more boost without issues. Make sure you have the fluid full and no air bubbles in it, then enjoy!
re my lack of license in mail, do you want to do up a form or leave it for the day. Also should I be chasing someone at aasa?
Yeah look I think the best thing to do is to ring AASA and ask, thats going to get a much better result than us worrying about it on the day to be honest (which probably wasnt the best suggestion from me haha), the process is that after the day we send a cheque and all the application forms from the day direct to AASA, they then process them and send the actual license to the applicants direct in the mail.
It's never been an issue in the past, it could be something simple like lost in the mail - who knows! If they have a record of mailing it, tell them it never made it and to please send another. They shouldnt have an issue with that :)
Edit; yep slower is faster, damn right!!! Shame it isnt as fun though :D
Slower being faster I've always found way more fun then just sitting in the middle of a patch of concrete with my foot held down doing skids...
If anyone thinks it's not fun to run a quick time, get in the car with Reece and tell me whats more fun, doing a skid or going balls to the wall...
i used to compete at motorkhana's on dirt when i was young in a datsun 1200. so i kinda know what its about, im not going out there to set times though.....not saying i wont try on a couple of runs, but i want to have fun
Hey guys about the helmets that are in that link, i sent an email to the guy on the central coast and apparently they will not be accepted at eastern creek it does not have a 5 tick aus standards lable or something like that, im trying to find a helmet for the drags/drift at the creek so i can start going but having some troubles getting one online for under $100
Unless you know your EXACT helmet size, you probably shouldn't buy your helmet online anyway... The helmet has to fit you properly with little to no movement for it to do its job.
I'd suggest going down to your local motorbike/motorsports accessories shop and let them know you have a budget, and ask them to help you find a helmet that you like and fits properly.
I got one I use for these days from Sydney City Motorcycles (google for locations near you). They have them all on display and you can try them on. Also prices were clearly marked to save time. Mine is open face, plain black and was about $80 from memory, fine for these days
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
