hey guys, recently bought some rpf1's for my 34gtr. they came fitted with some 265/35 r18"s and look stretched.
im looking to fit some new rubber asap but just struggling with what to choose size wise!
i have seen ppl with 34gtrs with same size and offsets running 275/35s, 285/35, 285/30 and 395/30! im looking to fill the guards out. would a 30 profile be too much of a reduction in sidewall height with a 285? i was looking at the federal 595 evos. would this size throw my speedo out too much??
really stuck on the one fellas!! any help would be greatly appreciated :P
expensive car, expensive wheels, and youre looking at cheap tyres?
a 10.5" wide wheel should imo have a 305 tyre on it..but I doubt you would fit them in the guards, so either a 275 or 285.
I was running 275/35s on my 9.5" wheels. I think the 395/30 is a typo haha. I would use either 295/35/18 or 315/30/18. I have 265/35/18 Federal RSR Tyres on now and love em, now just hoping they last a while, other reports say they will.
sorry yes, i ment 295/30. i didnt realise federal were that bad zebra? i had the evos on a few other cars and found them to be very decent.
ok will have a hunt around tomorrow for larger sizes in the 35 profile range.
thanks guys
they are decent..but there are much much better out there, depends on your budget though I guess
forgive me though because I thought I read 595 SS and not evo >_<
the largest federal make in 18" is a 285! however the 595evos come in a 285/35 profile, yet the rsr only in a 30.. a 285/30r18" is too low a profile and throws the speedo out crazy... apparently.
as i said before i have had the evos or previous cars and had nothing but praise.. however i must admit i never pushed them to the limit.
i wonder if i could fit 305/30r18's or 315/30r18s on a 10.5" rim?? plenty or quality available in thoese sizes
yes my house-mate had the 595 ss on his jzx100.. and the grip level was non existant and the noise from them was crazy...
i found the evos to have a much thicker and solid side wall then the ss and gripped much better. the said house-mate has actually just fitted evos and now struggels to break traction.. he still can, just requires much more effort
Why would you use federals on an R34 GTR , pinch.gif WWW.KOUKI .CO.UK - this site calculates speed differences between the tyres you have now and the tyres you want , very handy !!!!!!!!!
i use a set of Hankook ventus RS-3 275 /35/18 if your still not happy use some spacers !
Because they are cheap tyres which does not provide any sort of grip? They are probably the better ones of the cheap tyres around but still, get some decent tyres
+1
this is a daily driven car here guys. may i ask which federals you have had personal experience with and exactly what the bad points were? im only asking for help fellas :) , i had read good things about them... but if you say they are rubish then i will keep looking. if im going to do track work i will of course use something much more suitable. thanks guys
Federals bad?
They aren't, there is a difference between the 595SS and RS-Rs though.
Especially if you're only street driving, the evos/ss would be fine. RS-Rs for the occasional track day and are a great tyre for street even, but they will wear quite quickly. 140 tread wear.
If you are "street-driving" get some china tyres like ling longs or zeetex then since you are only "street-driving"
I dont get why ppl send 2-3k on rims and spend 600 bucks on tyres cause they are only "street-driving"
Each to their own
Thanks for the input ichi-go.. im simply asking questions and for advice. what is with the " street driving" comment? im asking for advice on a decently priced tyre to go on my day-to-day car.
Owgasm- thanks mate, i think im going for the rsrs in 285-30r18. they are very decently priced!
Hank scorpio- any idea of the $$ either of these tyres go for in that size? and reccomended sellers? cheers!!
Edited by alex.a
For the Toyo R1Rs, SAU trader Taleb Tyres should have them in stock at a great price.
As for the Yokohamas...
http://www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=ADVAN+Neova+AD08&partnum=635WR8AD08&vehicleSearch=false&fromCompare1=yes
:thumbsup:
Buy the best tyres you can afford, they are the only thing in contact with the road, I would rather spend more money on quality tyres than try and save money by buying pov spec.
And as long as your not running stupid camber/alignment settings they will last a while anyway.
Shop smart, shop S Mart.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
