Hey guys,
Had a guy off the forums come down and buy my catback exhaust that was for sale..
Whilst we were chatting about our cars he brought up the grill on the front of his, after going around and taking a look i was surprised. I had never seen nothing like it before but at the same time it looks amazing!!
Can anyone identify this grill and maybe link me to somewhere where i may be able to purchase one from.
Thanks and looking forward to everyone's replys.
https://www.sau.com.au/forums/topic/383851-what-is-this-grill/
Used to have the N.A series 2 grill as shown in my gallery but makes me look like a old fella driving the car lol so i swapped it for the dolphin grill.
You can pickup next to new condition N/A series 2 grills on ebay for under $75, To my understanding the dolphin grill still holds it's value..
Im still puzzled as to what aftermarket manufacturer makes this item... lots of views on the topic but nobody seems to have any idea on who may make it.
Reckon you could post a better photo?
It's a bit hard to tell if it's any good when it's not in context.
need one of the whole front of the car.
Hey chef
I actually own a series 2 and previously had the na grill but swapped it for the dolphin grill.
Both identical but i beloeve the na series 2 grill is alot rarer to find as opposed to the turbo grill.
Look wicked in context I've been searching yahoo japan auctions, I only found a front bumper that sort of resembles the grille, But before that i thought it may have been a takero's variant.. Which it was not.
But will let you know if i ever manage to stumble across one.
Found this Badboy. :thumbsup:
http://www.nengun.com/auction/item/m88615965
Doesn't have that line through the middle of it or the mesh behind it either. but I'm sure if you know a good body shop they might be able to add those bits in!
http://www.nengun.co.../item/m88615965
And by a "Good" Body shop, I meant yourself, with a fiberglass kit and a carton :laugh:
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
