  • Replies 41
you know what? f**k work =D
i'm in, tentatively.
haha obviously you did :P
if you come past Maggie's place gimme a buzz I might come out
cbf driving to her's then back to Doncaster then back her way again lol
Yea had a lot of fun. Went back through toolangi and kinglake to get home. Almost hit another 8 wombats. My bro was counting lol. Sorry for the offroad driving that went on for 15km or so..Was definitely different.
Thanks for organising it all James. Mt Donna Buang was pretty cool at night
was good night, thanks to tonys mate martin for leading us to mt donna buang, and thanks to nathan for leading us back through the 20km 4x4 off road track LOL :P
link to pix
http://imageshack.us/g/546/img0051sf.jpg/
Wow, I don't know whether to laugh or cry. I'm relieved you find amusing though Nate.
I rememember once we had a motorcycle ride similar to this, maybe even the same area. Except there were over 100 bikes... And many stacked. Handy to have four wheels in that situation!
On my way home, a poor rabbit on Eltham rd decided to play daredevil and ended up feeling the tread on my front left tyre… lucky I just saw it and pressed my brakes, otherwise i would have had a nice imprint of a rabbit on my front cooler.
Guest
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
