I was wondering what would be a reasonable but yet powerful turbocharger to substitute the stock one that comes with a rb25det neo, i am aiming to get my r34 over 300rwkw,
current mods:
x-force turbo back system
k&n apollo cold air intake
Any help is appreciated :)
https://www.sau.com.au/forums/topic/384116-turbo-upgrade-rb25det-neo/
Mate there is a lot of things to be done to your engine besides just bolting on a new turbo to get this sort of power....ie supporting mods - injectors, fuel pump, intercooler, boost control, engine management to name a few.
you want to spend 2k max, not laughing at you but id atleast double that amount to achieve your goals reliably.
Mick
was preferring something less expensive since i dont have a vast budget, something under 2k? pinch.gif
under $2k total eh.....
Do you have any thoughts on what engine management, injectors, fuel pump, FMIC you are going to buy to get to 300rwkw?
To clear things up, i just started researching and planning my mods, im willing to spend more but i am looking for a turbocharger under 2k.
As in supporting mods go:
Fuel pump with regulator + hks fuel rail kit
Front mount
Apexi power fc
Thats naming a few too, saying that i need clearing up on what is the right order regarding those mods. If you guys can suggest other supporting mods and an order, that would be great too
Budget setup cant go wrong with a kinugawa td06sl2 20 or 25g $850
ebay s/s high mount manifold $220
40mm or bigger ext gate $300
Walbro fuel pump $130
Deustchwoeks injectors (or highflows) $450
Z32 $200
Nistune $1000
Fmic kit $400
Rough prices on parts but that will basically get u to 300rwkw.
You do not need a hks fuel rail.
ebay manifold???
deustchwoeks injectors???
walbro fuel pump???
40mm or bigger gate
can you get anymore crap parts in one post?? jesus...
oh and of course it just has to be a 35R and highmount to make over 300rwkw doesnt it, cause thats just so cool eh...
total crap...
Thanks for your time guys first of all, i also got a recommended a GT3076 or a ATR43G3 FNT they are both easy to install with minor modification as long as bolt in goes, so i guess it would be a choice out of the two. How would i go about finding a high mount manifold?
Lol...high mount manifold for 300RWKW.
IB4L and "Thread closed. Believe it or not, but since SAU started more than 7 years ago, this topic has been discussed before....."
    • Sorry, just assumed that talk of coloured pads meant EBC red/green/yellow/shit stuff. I don't know the DBA pads, but it's a reasonable bet that they will be OK. DBA make good stuff generally. Those 4000 series rotors I linked to are very good. I may well replace the RDA rotors I have with those when required.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
