r34 and r33 both have 370cc injectors, i had my r33 at 12 psi with the same turbo by the sounds of it (3071 with the vg30 rear housing)
i had much the same mods as you and it had 200rwkw at 12 psi and was still running rich, so 14 psi should be ok i'd think
I haven't heard of many people safely pushing more than 230kw with stock injectors, at 14psi hard to say as I don't know what turbo you have but you will probably be ok.
If you are running stock AFM you will be close to maxing that out as well.
I just assumed he was getting a retune... waste of time if you use stock ecu imo.
edit: nistune is next, the car will run like an absolute dog without a retune, get a 10psi spring and leave it at that, even 10psi will have it coughing and spluttering though with the bigger turbo.
Edited by Rolls
Id say the fuel pump would run out before the injectors.
If your tune is conservative then you will be running very close to maxxing them out..
My stock turbo on 10psi with Walbro pump maxxed out the injectors easily when it was tune with a Link G4.
It's kinda hard to say whether injectors should be fine or not without any specific info about the turbo. But my advice would be to get a package of Z32 AFM, injectors and fuel pump before bolting it all together. These three cost around 1000$ for a new AFM, a set of siemens 650cc's and a Deatschwerks pump.
Yea, highflows may be okay, may be not, depends on how the've been modified, but almost always they're worse that injectors that come from factory with a designed flow. There are some good inexpensive offers for R34 injectors, starting from 50$/inj or there abouts. Search, there are some details about injectors suitable for NEO posted by forum members Simon-S14 and I think urtwhistle.
Jecs used to be an in-house electronics manufacturer for Nissan, e.g. my AFM has "made by Jecs" badge on it, so it might be a highflowed set of stockies.
Do you have a link to the said set of injectors?
Edited by Legionnaire
simon uses siemen deka injectors, the 3/4 length 60lb injectors are a direct fit but will just need to rewire new plugs. you can get this from the states the cheapest.
im runing 600cc high flows and havent had any fuel or tune issues. currently making 245rwkw and soon to be 300.
speak to PJ on this forum, i got them down thru him.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
