ive bought a boost controller cranked it to 10psi and regapped the plugs and changed to the r34gtt smic cooler... im now tossing up between an safc computer, z32 nistuned ecu and a full blown after market power fc or microtech setup. i plan on in the future going high flowed turbo fuel pump and injectors big front mount cooler would the cheap safc computer not be able to cope with theses mods?? i just dont want to buy stuff that i am going to have to update down the track. the z32 ecus nistuned are great but its just as dear as a 2nd hand power fc it seems....
https://www.sau.com.au/forums/topic/384278-ecus-and-stuff-doing-my-head-in/
make sure you go to a place that specifically does the Z32/nistune setup for R33's and tunes them for a set price.
They are often a fair bit of trouble shooting to get all setup correctly so there is the possibility of a place screwing you by saying it will 'probably cost about x' but then give you a bill that is double that 'because it took so much work to get it setup right'. Heard this story quite a few times...
And even though i went this route the first time and all was good. When i upgraded turbo, injectors and Z32 i went to a different place and when they said it would be about $300-$400 to tune as it would be just rescaling the existing tune and then adjusting for the new boost/turbo. Well when i went to pick it up there was a nice $1000 bill because 'we couldnt get it to work off the existing tune so we had to start again and tune it from scratch...'.
F$%K. nice one....
Have a read on here of people using the Z32 + NIStune setup.
It just seems like way too many horror stories and headaches to me. If it was any other car, I would recommend the NIStune whole heartedly, I have one myself and I love it. But in an R33, it seems like too much of a 'patch-up' type job. Especially in light of needing an 8-bit ECU instead of a 16-bit; that is so easy to get wrong and then before you know it you're hundreds of dollars out of pocket.
1000 dollars and your set rather then 2 for PFC
Way off. A series one or two RB25 PFC can easily be had for ~$1000. Have seen several for sale recently under that as well. And if you're willing to purchase one without the hand controller then that knocks another couple hundred off.
Edited by Hanaldo
I got mine for 600$..just saw one sell on ebay under 500$..
Its your best bet for R33 :thumbsup:
I ment 2 for buying the ecu and getting it tuned properly then yes 2 would be a realistic figure to but them on there own 1000 yes your right. Nistune cost around 1000 fired tuned drive away not so cheap when you go a new unit. Also y risk getting a PFC and getting caught by popo and having a red sticker slapped on your window. Stock look is best
It doesnt have a useable knock control.
BSA z32 nistune isnt quite that cheap due to needing a z32 ecu to start with. They sell for around $300ish. And as mentioned they have to be the correct type.
And yes there is a bit more tuning time involved. If i give a quote for tuning the only time its more expensive is for labour if needed.
Just bought an 8-bit z32ecu off ebay for $100 (it is on the nistune list)
$308 to send the ecu to nistune to have the type 2 daughterboard attached an r33 base map installed.
$350-450 for the tune (according to mods) stage 1 mods so far.
Hopefully that'll be all until i save up for injectors,turbo etc....
Edited by kosmo90
Fair enough I stand corrected sorry guys. In worried now using my 20 nistune on this 25/30
As its been stated before in the 30 thread, get the ECU for the head you are using (RB25DE R32 / RB25DET 33 OR RB25DE 33/RB25DET NEO/RB26DETT) and use all the sensors that are originally appropriate for that head.
Running a 20 computer on my RB30...No issues whatsoever. The only time you WILL have issues is if you try to mix and match sensors from one head/ecu with another. Obviously this doesnt apply to EVERY sensor...but overall the above statement should be followed.
What head?
I'm using an RB20 NIStune on my 25/30 but it's an R32 RB25DE head so everything is RB20 setup, no dramas :thumbsup:
Had no idea that the knock control didn't work?
The knock control is a little unreliable because of the stock knock sensors, it happens every so while where the sensors detect knock that is just noise and the ECU just jumps to the knock map. Often tuners just won't setup a knock map and instead simply copy the main map across so nothing changes.
Personally I've added a little fuel and pulled a couple degrees up top just to be safe, but for anyone who doesn't have access to the software themselves and can't reset the codes then it can get a little annoying.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
