  • Replies 5.5k
Posted Images
Red Bull and the mafia have pulled out of the FOTA.
http://www.autosport...rt.php/id/96614
"Red Bull Racing can confirm it has served notice to withdraw from FOTA (Formula One Teams' Association)," said Red Bull in a statement.
http://www.autosport.com/news/report.php/id/96618
the mafia.
http://www.autosport.com/news/report.php/id/96617
Edited by tweety bird
LOL The fuzz and Redbull pull out of FOTA!
Well well well... Now we know who wasn't spending within their limits don't we
You dirty little liars. I feel much better about Redbull winning the titles now. There's your explanation! Fererri were never going to attempt it anyway, Enzo would be proud
Ofcourse they all want to spend more money?! That's the issue.
Seemed to have missed the point of an RRA altogether
There's clearly two teams who can't, or won't, comply for the good of the sport and that is what is disappointing
Yeah, and I bet it's the two or more teams that are so strapped for cash they have their team principals cruising the grandstands selling double handjobs after every race.
Including the pretend teams and giving them equal say as opposed to established and well financed teams is always going to end in tears.
f**k this no testing tripe off, what kind of series is this ? What a joke.
biggest cheque book wins
k go
Actually, what really impressed me was Renaults effort in '05 and '06
Nowhere near the budget and unstoppable before the whole massdamper-gate
Yes you can argue, given a reliable car Kimi would have left them all for dead, but thats not what happened. Nando won both fair and square, even with some rubbish stewards calls which seemed to me a little biased towards his rivals
Some fantasitc races in those couple of years
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
