  • Replies 5.5k
Posted Images
FARK YEH!!!!!!
Burn in hell RBR. I will continue to show a minor interest in your BS team because Old Son Mark is still a resident pilot in your squad. But for 2012 I will wear my Renault-Lotus Black and Gold with pride baby!!!!! :worship: :worship: :thumbsup::worship::thumbsup:
So happy for Grosjean...he will do well alongside Kimi, who wont be out to play mind games with his new upstart team mate....good combination in my books. And hats off to Lotus managment, in particular Boullier for grooming a guy...realing his talent and then giving him a seat. Not something that happened under Old Flavs watch :cheers:
:worship: FARK YEH!!! Now I am pumped for 2012 :)
I already have the jacket because I love Lotus...even if to some its not the Lotus (road car or F1 team) of old....I just love Lotus vs all the homo Itlian and German junk on the road :)
I imagine there is going to be a lot of disappointed Russians out there...but ... I liked Petrov, but he whilst he had good race craft and was a great defender and character....he lacked a bit of the outright pace needed to be in a top F1 seat.
For people who'd like to be able to see whats going on: http://www.redbull.com/cs/Satellite/en_INT/Video/Milton-Keynes-Home-Run-021243135554224
Mobile version looked a bit like this: http://i.imgur.com/EsCPr.png
Edited by irokin
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
