  • Replies 5.5k
Posted Images
also, for your enjoyment
the new mclaren front end
ver nice. LM-style vents over the front wheels are cool. can't say I've ever liked those optional wheels, but nothing a set of HRE's or similar wouldn't fix.
75hp is a not-inconsiderable increase. would run sub 3 sec to 100 for sure with 667hp and some corsa tyres.
at 660hp+, 1400kg, with 200mph+ top speed, 3 second 0-60 and a price tag of £168,500... this is the car to have
bang for buck, its almost unbeatable
except they are only making 5 of the HS models to keep them exclusive :blink:
Speaking of collecting shit
A lot of teams are selling their 2011 apparel and merchandise at a massively reduced price if anybody is interested. I know Mclaren is 50% off almost everything... sh@un...
which sites do you recomend for cheap merch
Is that at a specific shop? RBR prices all seem the same
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
    • Did you even watch the video? Its not a steering wheel.
