  • Replies 5.5k
Posted Images
That's an interesting looking array of sensors on the macca
Yeah Alonso hasn't been out for ages - whats the story there? Also the Tool hasn't been out for almost as long
hydraulic failure if i remember correctly
and no low fuel runs by either ferrari or mclaren while at jerez
so nothing too exciting on the horizon
http://planetf1.com/driver/18227/7498927/McLaren-brush-off-nose-concernsNo shitty step-nose for the Mac?I think I may have to back team brit until the Fez can get their shit together (I feel so dirty saying that, but I do like Button, it is like wanting old mate Mika to do well haha).Please, spare me the form>function jibe... Many a winning car have been beautiful machines in their own respect. I think the only team that have made the step-nose look half decent is Lotus (old Renault), with an honourable mention to Redbull. The rest are absolutely crapola!Please please please Merc, do not release a bloody step-nose!
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
