I have the following tickets for melbourne f1 forsale
2x thursday not sure of stand.
1x friday brabham stand
1x sat brabham stand
Ive got 2x 4 day but mate will only b here for sunday. Walk in with me. So no doubts of fake tix etc not sure wat its worth. Msg me 0400099986 even just pay for few beers :)
  • Replies 5.5k
Posted Images
Ok predictions!
My 2c. From fastest to slowest teams for quali. RBR > McLaren > Lotus > Mercedes > Fezz > FI > Sauber.
My prediction for top 3 in Quali : Vettel, Button & Webber
Top 3 Race : Webber, Button & Kimi
And of course real interested to see if Diso Dan hands it to the young Frog :)
:whistling:
Biggest chin in F1 has to be worth some respekt. It has to cost him 3/10ths a lap at least just carrying around the extra weight and frontal aero issues it creates.
Interesting to read he has trimmed down some this season. Despite looking like a giant compared to the other jockey sized drivers he was still a pretty skinny dude last year. Less weight would be skirting with significant losses in endurance you would think.
I have one foot on each of the Capt Chin and Ricky-ardo bandwagons. Go Australia.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
