  • Replies 5.5k
Posted Images
Red Bull RB8 - revised exhaust positioning technical breakdown.
http://www.formula1....2012/0/940.html
same for McLarens MP4-27.
http://www.formula1....2012/0/939.html
World Champion Vettel initially wanted to christen his RB8 'Everybody's Wife', but eventually settled on 'Abbey'.
http://www.planetf1....-Kylie-to-Abbey
interview with daniel ricciardo here.
http://www.heraldsun...e-1226299351870
and here.
http://www.adelaiden...j-1226297575750
About to do a pit walk, melbourne weather sucks!
How did you do a pit walk so early?
I thought gates open at 10:30?
Can hear the cars this morning. Just about to walk over.
Iphone pics will be provided if there is anything worth taking.
^ don't be slack with the pictures boy.
in other news.
Argentina is on the verge of securing its return to the Formula 1 calendar, the country's president said on Wednesday.
http://www.autosport.com/news/report.php/id/98025
Opened up at 9:30.
Just got back. I thought the 'breakfast' in the morning would have been a buffet style breakfast not a sausage in a piece of bread with with a warm can of red bull! Anyway got some pretty good pics in pit lane. Going to watch the v8 races tomorrow
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
