Where is the f1 site timing?
Only has top 3 with no times :S
All the times come up for me?
Timing is here:
http://www.formula1.com/live_timing/live_timing.html
Or Here:
http://www.planetsport.com/live/f1/
  • Replies 5.5k
Posted Images
It's Practice - realistically means nothing. Plus half of P1 was wet.
After being in the Pits for a few hours today and watching the cars there is only one clear distinction so far.
The McLaren's look totally different to any other car out there today.
The nose cone and front section/aero is nothing like the rest of the field. It'll be interesting to see what occurs on race day. Is it an advantage or will the simply fall away?
Most other cars nose-cone & front end wise are reasonably similar.
^agreed if the Mclaren's have a good couple of good first races i think they and (button) will be hard to beat.
hope we might see tears from vetool;
http://en.espnf1.com/australia/motorsport/story/73105.html
All of us real F1 fans knew that quite some time ago Ash, but thanks for the corporate breaking news ;)
Anytime :thumbsup:
The other cars today appeared to have more corner speed compared to the McLarens @ T1
However the McLarens were on the pedal a lot earlier out of the corner.
Bet you didn't hear that in the pre-season internet jibber jabber.
even more promising is the combination of no-blo diffusers and tougher deflection testing of aero elements may have truly ended RBR's domination :happy:
    • Yea I could, but it is amusing how shit a stock seat and belt are
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
