  • Replies 5.5k
Posted Images
There could be no worse result for Massa than this...
His team mate on the top step, standing next to the guy rumoured to be his replacement, while he finishes 100 seconds behind... Might need to be locked in that padded room with Vettel
mmmm web stream getting it thru some software on my mac called xbmc and some other addons for channels, its not too simple to do however
Any links and help to setup?
they are probably frantically trying to download an anthem to play for him, LOL
LOLOLOLOLOL
Interesting season ahead.
Perez should have won.
Damn team played him twice. No pit and wrecked his flow on the radio.
hahahaha, some silly bitch had a bit of a rant on the ONE fb page complaining about people on facebook spoiling the results by talking about it on facebook, because she lives in an area that only gets channel 10 and not ONE so has to watch the delayed broadcast.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
