  • Replies 5.5k
Posted Images
There could be no worse result for Massa than this...
His team mate on the top step, standing next to the guy rumoured to be his replacement, while he finishes 100 seconds behind... Might need to be locked in that padded room with Vettel
mmmm web stream getting it thru some software on my mac called xbmc and some other addons for channels, its not too simple to do however
Any links and help to setup?
they are probably frantically trying to download an anthem to play for him, LOL
LOLOLOLOLOL
Interesting season ahead.
Perez should have won.
Damn team played him twice. No pit and wrecked his flow on the radio.
hahahaha, some silly bitch had a bit of a rant on the ONE fb page complaining about people on facebook spoiling the results by talking about it on facebook, because she lives in an area that only gets channel 10 and not ONE so has to watch the delayed broadcast.
