  • Replies 5.5k
Posted Images
Pirelli in new push for qualifying tyres to solve Q3 issues
Pirelli motorsport director Paul Hembery is pushing for formal discussions about a revision to the Q3 tyre rules at the next meeting of the Formula 1 commission.
Amid fresh concerns about teams electing to not run in final qualifying so that they save tyres, Hembery is eager for more talks about the idea of specific qualifying tyres.
"We need to get all 12 teams together and I will certainly ask to put it on the table at the next F1 Commission meeting," he said when asked about the situation regarding Q3-specific tyres.
"Bernie [Ecclestone] is keen on it. He does not feel [cars sitting out Q3] is good for TV and we have been on record saying that. But, equally, we appreciate the teams' point of view. And it was unanimous when we last spoke to them that they felt the tactical intrigue created by not running and having fresh tyres was something that was good for the sport. Where the real solution in that lies I don't know.
"We will offer what is needed and that can be anything from an extra set for those in Q3 to make them run, through to full qualifying for everybody. We are open to whatever solution the sport feels is best, but we feel running cars in Q3 is important."
Despite Pirelli's push, and Ecclestone's support of the idea, teams are not keen on the idea of changing the current Q3 rules, under which drivers must start races with the same tyres that they set their fastest qualifying time with.
However, some team principals have suggested that the ultimate decider should be the fans at home.
Mercedes boss Ross Brawn said: "There are two sides to every coin and is the show spoilt by the fact that some of the cars at the back of Q3 don't run? I'm not sure it is. I think everyone's focused on what the guys fighting for pole are doing. But if there was genuine proof that the fans want 10 cars running all the time in Q3 then we'd accept some extra tyres."
http://www.autosport.com/news/report.php/id/99877
Pirelli to the rescue!
p3
Times
01 Nico Rosberg Mercedes 1:15.159 25 laps
02 Felipe Massa Ferrari 1:15.197 0.038 21 laps
03 Sebastian Vettel Red Bull 1:15.209 0.050 20 laps
04 Fernando Alonso Ferrari 1:15.210 0.051 20 laps
05 Romain Grosjean Lotus 1:15.445 0.286 18 laps
06 Jenson Button McLaren 1:15.471 0.312 19 laps
07 Lewis Hamilton McLaren 1:15.734 0.575 19 laps
08 Michael Schumacher Mercedes 1:15.893 0.734 23 laps
09 Sergio Perez Sauber 1:16.110 0.951 14 laps
10 Mark Webber Red Bull 1:16.219 1.060 19 laps
11 Jean-Eric Vergne Toro Rosso 1:16.226 1.067 20 laps
12 Kimi Raikkonen Lotus 1:16.301 1.142 21 laps
13 Kamui Kobayashi Sauber 1:16.311 1.152 19 laps
14 Daniel Ricciardo Toro Rosso 1:16.479 1.320 20 laps
15 Nico Hulkenberg Force India 1:17.027 1.868 20 laps
16 Bruno Senna Williams 1:17.055 1.896 26 laps
17 Heikki Kovalainen Caterham 1:17.276 2.117 25 laps
18 Paul di Resta Force India 1:17.390 2.231 19 laps
19 Vitaly Petrov Caterham 1:17.404 2.245 22 laps
20 Timo Glock Marussia 1:18.259 3.100 18 laps
21 Pastor Maldonado Williams 1:18.488 3.329 22 laps
22 Charles Pic Marussia 1:19.099 3.940 17 laps
23 Narain Karthikeyan HRT 1:19.147 3.988 19 laps
24 Pedro de la Rosa HRT 1:19.151 3.992 19 laps
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
