Massa had enough room, didn't yield once he was taken and caused the incident, he aimed it at the tyres and kept on going, why he freaked and spun it makes me think he was trying to cause rbr penalties. He's good enough to have done otherwise and chose not to, for what ever reason.
  • Replies 5.5k
Posted Images
The guy on the inside/racing line doesn't have to yeild! It's his corner. You can legitimately drive out to the edge of the track and run the guy on the outside out of room if you want. When they collided they were only mid track just after the apex. If you're going round the outside, you're making your own arrangements - you have no claim to the corner. That is the way its always been.
only once massa over rides the second kerb does he send himself into a spin
as per usual he'll use any excuse to shield himself from the truth of his own inability
3rd kerb? which is also the normal racing line...
and the fact is you can hear he was off the throttle when the spin started and only picked the throttle up when he was had done more than 90degrees to try and keep the spin going and hopefully end up pointing the right way...
they've also got data showing he hit the brakes hard as Mark rejoined the track right across his nose onto the racing line, which is a big no-no normally... as is completing a pass off the track. How Mark escaped without 3 drive-thru penalties in that race I have NFI
Yarr, the third kerb
Fact is, it doesn't matter at what point he got back on the throttle, he had already managed to be back in control of the car by the second kerb. But because he's a punk bitch, instead of continuing the line he deserved, he back off and caused that spin all by his lonesome. His inability to assert himself manifests itself on track and pigeonholes him as an easy target
Webber blasting past certainly helped him into the spin, but he did not cause it. You wouldn't imagine Webber trying that on Alonso or Lewis
Also i agree, webber deserved an earlier drive through, but thats somewhat unrelated
Edited by ctjet
sif there is any alcohol consumed in the middle east.....
there are bars/clubs here,
but i've been told they're more for meeting errr........... ladys of the night then drinking.
Webber completed the pass outside the track, so he would have been forced to give it back. As Massa had spun (regardless of whose fault it was) he couldn't give back the place he gained illegally, so he should have been penalized. Pretty simple really
The real shame is that Massa didn't rip a skid across Vettel's front wing
Is that really true though?!?! Forget the Webber incidents etc for a moment. Just generally...
Historically they gave each other room. Then with increases in safety and tracks with run off emerging as the norm you started to see guys more commonly being forced wide. Typically you used the exit and compromised their run in the corner...but I am not sure I accept the "you run them out of room/track theory. God knows its dangerous making blanket statements as moves around the outside are common in flip-flop/S-bends etc.
But I do agree that the guy on the inside has the line and advantage and has the right to hang around , but if he is a wheel behind on a compromised line for the exit as he is entering so shallow then I am not sure its so clear cut.
So jumping back to the Webber theory I just dont think its so clear cut. If you try an outside move on a 90deg corner you have to expect you are going to be pinched on the exit these days and probably forced to take to the run off area as they take the line on exit if you are anything remotely wheel to wheel. This is where you are better trying to compromise their entry then get a better exit with the over-under style move.
But on a flip flop/S-bend the guy on the inside has to get back to the other side of the track asap to get a good run on the exit of the second bend. In the case of Webber-Massa, Masa forced Webber off the track after a dive bombing wheel clash when hsi normal line would have been to hand left on exit so he had a more optimum line for the second half of the corner. So you are free to tae the normal line but I guess to e its blurred with racing craft when you hang around the outside hoping to gain track position and the inside line for the second corner or final 90deg part of the croner
Once someone gets 3/4 of the car past you perhaps it is time to roll off the throttle a little earlier and leave some racing room (drivers in the BTCC are excluded)
yes - IF they are on the inside and half way alongside, it is their corner. The guy on the outside is the one who should be rolling off the throttle.
All I can say is you guys would be singing a different tune if it were Maldonardo on the outside and Webber or Hamilton on the inside...
but I probably would too :P
Edited by hrd-hr30
Bernie Ecclestone has revealed that Magny Cours is the only circuit he will consider if the French GP returns to the calender.
http://www.planetf1....for-2013-return-
http://www.youtube.com/watch?v=J4q0DeZVusM
McLaren team principal Martin Whitmarsh has confirmed that the team intend to run with Mercedes engines for some time to come.
"It is going to be McLaren Mercedes for quite a few years to come," Whitmarsh told the the Daily Mail.
"It is a good partnership and it works well. We've been together for 18 years and it is going to continue for quite a few years to come.
"I think we have got a very good deal with them, but I think more importantly than that is we have got a good partnership.
"Obviously I've been involved with Mercedes personally. I ran the engine side so we know the people, and we are proud to be part of the Mercedes-Benz family."
http://www.planetf1....n-with-Mercedes
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
