hey guys i was looking at my engine bay tonight and thinking how to clean it up a little. now im running a microtech which is Map sensor so no afm and it doesnt use the aac icc valve. now the big hose that goes from the elbow of the crossover pipe to the plenum/aac valve. now i dont think the aac valve is in use as theere is no plug plug into the purple plug on it. can i remove this pipe and blocke it off as im soon to be running external gate off the stock manifold and this hose may get in the way a tad.
https://www.sau.com.au/forums/topic/384322-piping-for-aac-valve/
  • Replies 47
Posted Images
I would keep it there untill not needed. I mean run your piping similar to mine that way there is no mucking around blocking stuff off. What about front facing plenum? Totally get rid of all the clutter
thought of that but for the power im going for its not needed plus ill need to remove all my battery and redo all my piping its in a vl btw
That is true I'm just lucky on those kind of things. You found anyone over there to make you one of those manifolds. I'm mucking around trying to see if the wastegate can be fitted under the manifold and turbo get it out of the way a bit also keep it looking low key on the stock mani
yeah the boys at ovaboost can do it for me however let me know how you go for the low key side of things as im using this for street however i wouldnt mind seeing a external gate sitting there haha
eventually ill get a forwrd facing plenum JD customs ( a advertiser on calaisturbo makes a forward plenum for rb25 that bolts onto stock runners
As for the hose spigot, if your AAC isn't utilised then block everything up.
As for the plenum, I had a custom one made using a GTR plenum chamber and stock RB20 runners (RB25/30 with an N/a non-vct head) and a Q45 t/b on the front positioned so that I could utilise the standard GTR cooler/plumbing I fitted up. No relocation of battery etc. Barely cost more than a FReddy manifold.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
