Daboss Posted December 2, 2011 Share Posted December 2, 2011 Hey forum just need an answer to a question about the stated topic. A friend of mine has a rush racing antilag device that he cannot get to work, it is a simple three wire hook up and a few simple button presses to install, only problem is for some reason it doesn't work with his rb25det series 2 engine. Wanted to know if it doesn't work because the engine is a series 2? The signal is suppose to be attached to wire 52 on the ecu, but on series two motors the wire harness has no wires attached to pin 52, so we are forced to use pin 42 with no luck. The instructions say to install the signal wire on pin 52 which is the crank angle sensor degree 1. We then have to install on pin 42 as that is the pinout that is crank angle sensor degree 1 for the series 2 engine but when we try to set the car drops rpm and dies with a loud backfire. Same thing happens when trying to install a bee r rev limiter. I know the antilag works for sure as we installed in a friends supra and it worked liked a charm, tried it in my series 2 as well and it also did not work. Can rush racing antilag systems work with the series two rb25det? Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/ Share on other sites More sharing options...
luvpsi Posted December 2, 2011 Share Posted December 2, 2011 Best bet if you wanna use anything like that the bee r limiter works on rb25s Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6136667 Share on other sites More sharing options...
GTScotT Posted December 2, 2011 Share Posted December 2, 2011 You must be wiring it wrong, get a pinout diagram before you go any further Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6136710 Share on other sites More sharing options...
Legionnaire Posted December 2, 2011 Share Posted December 2, 2011 Got a link to the device, it's description? Got any instructions? Backfire is a good sign if you're trying to set up antilag, it means the device is actually trying to retard CAS synced events, i.e. injection and ignition. Maybe it does a little too much retardation though. What are the other two wires, power supply? Is the device adjustable at all? Is there "idle" mode of any kind, when ALS just sits in there without adding any delay to CAS signal? Does engine work properly when the device is wired in but is not active? Is your or your friend's ECU adjustable, like Nistune or something? Tried to do any logs? Maybe there isn't enough fuel for the engine to actually run, or maybe O2 closed loop routine is doing funny things, or a bunch of other reasons that could affect engine/ECU behaviour. Oh, and I hope you're not trying to use antilag with the factory turbo. Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6137006 Share on other sites More sharing options...
zebra Posted December 2, 2011 Share Posted December 2, 2011 http://rushracingdev.com/al.html It isnt anti-lag, its just a 2-step limiter Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6137138 Share on other sites More sharing options...
Legionnaire Posted December 2, 2011 Share Posted December 2, 2011 So according to OP's post, it's intended to delay CAS 1-deg signal by a certain amount, based on current revs? I'm having hard time seeing it working as a rev limiter, let alone antilag. BTW, retarding 1-deg signal won't do a thing, because on 1-degree ring there are 360 slots on CAS disc that have absolutely uniform intervals between them. What should probably be delayed is wide slot signal also known as sync signal, because there are 6 slots of different width, and this very signal is actually responsible for synced/sequential engine operation. Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6137167 Share on other sites More sharing options...
zebra Posted December 2, 2011 Share Posted December 2, 2011 If what you are saying is correct than I assume it just retards the timing so much the engine wont rev any higher? Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6137172 Share on other sites More sharing options...
Legionnaire Posted December 2, 2011 Share Posted December 2, 2011 Yep, that's basically how soft limiters work - they pull some timing so that engine wont either gain or loose revs. That's the way some OEMs used to do it. But they also trimmed fuelling accordingly in order to smooth out normal-to-limiter transitions, avoid backfiring and keep engine temperatures and emissions in check, which the above device is cetainly uncapable of doing. Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6137191 Share on other sites More sharing options...
zebra Posted December 3, 2011 Share Posted December 3, 2011 I would love to try one along with an EGT gauge, hold it on the limiter and count the seconds before either a piston melts or the chamber melts, and the exhaust valves are soft and mushy, or a turbine wheel melts Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6137318 Share on other sites More sharing options...
Legionnaire Posted December 3, 2011 Share Posted December 3, 2011 That's exactly right, I'd expect exhaust valves to let go first, or maybe seize in their guides, and also think an epic exh. manifold meltdown could have been observed... or maybe head warpage Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6137361 Share on other sites More sharing options...
zebra Posted December 3, 2011 Share Posted December 3, 2011 I still have the stock ceramic turbos on the Supra...... Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6137365 Share on other sites More sharing options...
GravyGarage Posted December 4, 2011 Share Posted December 4, 2011 Also having problems hooking up my Bee-r. Ran fine with my 20 but tried to wire it into the 25 loom and no luck. Spent a couple of hours one day connecting it to different wires from different pinout diagrams with not much luck. Managed to get the controller working fine with all the lights doing their usual thing but it just wouldn't cut the revs... Could be a similar problem? Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6138411 Share on other sites More sharing options...
Daboss Posted December 7, 2011 Author Share Posted December 7, 2011 You must be wiring it wrong, get a pinout diagram before you go any further It is only a three wire hook up and I checked the wiring over and over it was wired in correctly. Even tried it on the 180 degree ecu pinout instead of the 1 degree and the result was the same. Wire 52, power and ground thats it. Also having problems hooking up my Bee-r. Ran fine with my 20 but tried to wire it into the 25 loom and no luck. Spent a couple of hours one day connecting it to different wires from different pinout diagrams with not much luck. Managed to get the controller working fine with all the lights doing their usual thing but it just wouldn't cut the revs... Could be a similar problem? Which rb25det do you have? I have the series two I have heard of people getting them to work, but everytime I ask which engine it seems to be the series 1. I do not know if that has anything to do with it. So was the bee-r we tried and the rush limiter. Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6143601 Share on other sites More sharing options...
Daboss Posted December 7, 2011 Author Share Posted December 7, 2011 Best bet if you wanna use anything like that the bee r limiter works on rb25s Tried the bee-r as well same result. Have you installed a bee-r that worked on a rb25det series 2 engine? Got a link to the device, it's description? Got any instructions? Backfire is a good sign if you're trying to set up antilag, it means the device is actually trying to retard CAS synced events, i.e. injection and ignition. Maybe it does a little too much retardation though. What are the other two wires, power supply? Is the device adjustable at all? Is there "idle" mode of any kind, when ALS just sits in there without adding any delay to CAS signal? Does engine work properly when the device is wired in but is not active? Is your or your friend's ECU adjustable, like Nistune or something? Tried to do any logs? Maybe there isn't enough fuel for the engine to actually run, or maybe O2 closed loop routine is doing funny things, or a bunch of other reasons that could affect engine/ECU behaviour. Oh, and I hope you're not trying to use antilag with the factory turbo. No it's an aftermarket turbo, give me a little bit more credit thatn that. Good looking out though Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6143605 Share on other sites More sharing options...
hypergear Posted December 7, 2011 Share Posted December 7, 2011 I've heard that running the engine super retarded on idle can infact spin a turbo like jet. (not sure if any one tired it). How ever once the car's driving the shaft speed drops back to normal. Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6143657 Share on other sites More sharing options...
DVS JEZ Posted December 7, 2011 Share Posted December 7, 2011 If u set the ignition table to 0 and hold the revs up u can hear the turbo start spooling with no load. 0 degree's timing probably wont drive the best though Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6143684 Share on other sites More sharing options...
DVS JEZ Posted December 7, 2011 Share Posted December 7, 2011 Are u sure there is no pin on wire 52??? Z32 and rb25 both series have the same pinout and they all should have pin 52 as pin 2 on the CAS. Ill check the colour of the wire in 10 when i walk past my drifter with series 2 25 Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6143690 Share on other sites More sharing options...
GravyGarage Posted December 8, 2011 Share Posted December 8, 2011 It is only a three wire hook up and I checked the wiring over and over it was wired in correctly. Even tried it on the 180 degree ecu pinout instead of the 1 degree and the result was the same. Wire 52, power and ground thats it. Which rb25det do you have? I have the series two I have heard of people getting them to work, but everytime I ask which engine it seems to be the series 1. I do not know if that has anything to do with it. So was the bee-r we tried and the rush limiter. Hmm mine is the series 1 engine and the ecu has s2 auto written on it. The loom looks like its a bit custom aswell (got the lot as a kit). Keen to hear results Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6144244 Share on other sites More sharing options...
W0rp3D Posted December 8, 2011 Share Posted December 8, 2011 http://rushracingdev.com/al.html It isnt anti-lag, its just a 2-step limiter The description on that page you linked to is: The Rush Racing Development Antilag Launch Control is the best way to get your car out of the hole in a hurry. Testing has shown boost pressures over 18 psi and so far, low 1.50 60 foots. This unit also works with manual transmissions as well as most automatics but results below 3500 rpm may vary. Setting the rpm is done with one simple press of the button and out performs other 2-steps. Installation is a snap with only three wires to hook up and no wires to cut. Be advised that this unit works more like the AEM antilag than the traditional 2-step, so flames from the exhaust are likely. WORLD WIDE SHIPPING AVAILABLE!. So how is not antilag? Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6144496 Share on other sites More sharing options...
zebra Posted December 8, 2011 Share Posted December 8, 2011 It is nothing like anti-lag Unless it somehow magically works by the shwartz when you change gear or get off the throttle Link to comment https://www.sau.com.au/forums/topic/384692-antilagrevlimiter-rb25det-series-2/#findComment-6144526 Share on other sites More sharing options...
