Hey Guys,
Went to start my car this arvo, since it had been sitting there for a while....
On the first start, it was miss firing quite badly, with a strong Fuel odour.
I switched my car off and could continue to hear a hissing sound, noticed my fuel switch was left on, and when turned off the noise disappeared.
I continued to diagnose and removed the loom's off all the injectors and turned the fuel back on, and the hissing noise came back (sounds like injector 1)
So I have come to the conclusion that my injector is seized open??? Or do the injector's stay open when disconnected (I highly doubt as they would continue to leak when car switched off)
Would taking them to an injector specialist help? or are they pretty much gone once this happens?
Cheers
https://www.sau.com.au/forums/topic/384759-injector-problems/
Your diagnosis sounds right. Injectors are always shut and only open when given a pulse. Try tap the injector cap. Then again when you think about it, it want seized when you turned turned it off last. If its a stock injector just replace it.
The injectors should be normally closed until switching power is applied.
It's probable that some gum has developed around the needle of 1 or more injectors. The cheapest option right now is to take them out and have them all sonic cleaned. This will at least give you an idea of whether or not they are still serviceable or if they need to be replaced. Adding injector cleaner when the injectors are this far gone has the same result as setting fire to a $20 note.
i cant speak for gtr, but my gtsts injectors only open with power applied. you might want to get an oscilloscope hooked up to the loom as the injector might be fine but the loom may be screwed. wouldnt bother sending them to a specialist. its usually cheaper to buy another injector 2nd hand
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
