LOL, No Paulie but my 3 litre is going back on the dyno with an intercooler upgrade tomorrow.
Looking forward to that.
I've been dreaming about that 3.3 litre for so0me time now. If I know me its bound to happen sooner rather than later. :whistling:
I dont want to start a shit fight but you cant use that bottom graph as a comparison as the two ramp rates are miles apart...
If you look at the first graph both runs start at the same point on the 3250rpm line.... this means same ramp loading.
Now look at the second graph each start point is differrent (about 10mm higher) this shows a completely different ramp rate (higher which gives false response gains)
Killer results, just not a good comparo. im sure its just an oversight.
Its a good way to check comparos in the future as we see it all the time.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
