  • Replies 73
That 'VSPECT' guy makes awesome maps lol
If you've forgotten about my C-spanner James :P if you bump into Sunkist or Penguyen tonight could you pass it on to them and I'll grab it off em tomorrow :D
Don't worry tony I haven't forgotten about it, was actually hoping you'd come out tonight il try drop it off during the week after work
Glad you's are enjoying them, nothing i love most then meeting/cruising with people that have the same interests
And no problems dude as long as you have someone's number that's goin to be there to let them know, because don't want to wait around if you don't end up coming an we don't know lol
I'll keep you posted.
Since I don't have anyone's number, I'll post here 9:30ish to let the crew know if I'll be making it down and an ETA.
lol...alex this is when less traffic (means more fun ;) ) ... i noe fri nit sucks by hey i got work at 7 too...so dw abt work...just rock up n have fun.. :D
yeh i just live to far away its an hour + just to get to meet point
have fun anyway, hide from the cops :thumbsup:
I had nothing to do tonight. So just went up there, picked up tony's c spanner, talked a bit, went home when they left for cruise. Haha.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
