Hi all
Ok the molds for the sub enclosures are complete so i will now be taking orders
Price per Enclosure will be $200 carpeted in as close as i can get to stock Grey carpet. The enclosures will be supplied without terminals (terminals can be bought for $8), this enclosure is to suit the passenger side
A 50% deposit will be required to confirm the order, PM me for banking details
I would like at least a batch of 5 to cover my inital costs i.e molds and labour, so once 5 orders have been confirmed i will start construction the turnaround will be approx 7 days
The approx thickness of these enclosures is 5-8mm, with a seamless top section and a 16mm mdf base
Will Suit 10" or 12" sub-woofers upto approx 170mm deep
(I personally have fitted a DLS MW12 with ease to my own enclosure)
Post here if you are interested or have any Q's
Here Are a few pictures to see what they look like
Fresh out of the mold with slightly improved curves
(excuse the dust)
Edited by Fgjoh
https://www.sau.com.au/forums/topic/385044-c34-stagea-sub-enclosure-gb/
  • Replies 50
Hey Mate, Would definitely be keen on one (or two) of these but have a few questions first.
1. Are you able to supply and fit the terminals if the additional $8.00 is paid? Or make it $10 for your troubles.
2. How can you access the Attessa bottle behind the Amplifier on the Drivers side?
3. What does the Passenger Sub box attach to and vise versa for the Drivers side?
Really cool enclosure though mate! Will lay down a deposit once I get paid :)
Cheers
Cheers
At the moment i won't be making a drivers side enclosure until there would be enough interest as it's a very labour intensive process
1. I can fit the terminals no problems($10 all up is fine to install it)
2. The enclosure can be removed quite easily(i dont see you checking the atessa more than once a month)
3. The enclosure uses the stock floor plastic bolts to fasten them down(dogleg brackets are used to do this)
a small metal tag at the top of the box slips underneath the plastic trim to stop it from moving(they are very secure)
Whats your location, and do you know what sort of cost it would be to ship these interstate if required?
I'm in Adelaide
Shipping should be approx $25-$30 to most states as i have sent items of a similar size
cheers,
Pete
Ok 2 enclosures have been completed so far, within the next few days the other 2 should be complete
I'll post some pics of scriblez new enclosure later in the day
Edited by Fgjoh
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
