Thanks for the good comments, Glad your happy with it James and if you need any other work done just let me know
Any chance you could post pics of the gauge pod once it's in?
Also do you mind if i use these pics?
Cheers,
Pete
  • Replies 50
I'm in for one. Will send through a deposit on Friday (payday :)).
I'd also bee keen on one for the other side. Actually, if you're after ideas, I'd be mega keen on one per side with a sub enclosure in the left and an enclosure for 6x9s in both. Now that would be absolutely awesome.
What do you reckon the likelihood of that would be?
hey just to let you know i will be up/down for a sub enclosure as well if i still can, just waiting on money from dad as it's my xmas pressie but he doesn't like internet banking so he's waiting till he can transfer it to me the old fashioned way, will pm you when i get it for ur bank details etc
Pm sent
I'll be starting another GB within the next day as i have had a bit of interest so far
I Also have a few new items
1. Pillar mount gauge pod
2. Clock Replacement dual gauge pod
3. Still working on this i"ll post some info once it's sorted
And the count for the drivers side enclosure is at 4 once it's at 5 I'll take deposits and build a mold
Cheers,
Pete
Just go the subbox today, fitted it and it's frick sweet next thing is to fit the gauge pod
thinking about getting the r/h one but need it for an amp.
Cheers
Just put this in my car,only put a base model sub in for now but love the sub enclosure!! Excellent work, will defiantly recommend anyone with a stag to get one!
P.s, pardon the gear box oil stain on the carpet. :(
Ok Time for a new thread
Here's the link
Fgjoh Custom Fiberglass Sub Enclosure And Gauge Pods
Please post in the new thread and let this one fall back
Thanks,
Pete
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
