Fabricate A Return Flow Intercooler And Other Stuff For Me? :)
Hey Guys,
After contemplating getting myself a tig welder and doing all this myself, i thought I'd check to see if someone on here is willing to and can do it cheap for me?
All this would be for my R32 GTST has an rb20
I would be after some return flow piping to fit this intercooler http://justjap.com/store/product.php?productid=19813&cat=298&page=1 with stock piping connections.
Also a new intake pipe with both oil and bov return pipes plumed in.
lastly I'd need a new V-band dump pipe made for the new turbo (kando TD05/6)
Now i realise the chances of any of this being done without seeing the car is small but what are the chances of say the return flow piping? Looking at getting this done first!
Anyone keen to give it a go. Doesn't matter if its done using lobster cuts or bending just as long as it works. :)
Thanks for any help.
I'll do it for you mate message me if interested 0449831518. I can come down there tho it would be easier if you could make it up to Gosford is that possible? Talk about prices and how you want things done when I see the car
Edited by Bsa
if your going to go return flow why dont you buy a return flow cooler??????
like the blitz ones or somthing similer
l
Purely because I'm cheap and that's an expensive kit for the r32 (700$ish) and I'm going to be painting it black too so wouldn't want to ruin one of their kits.
You'll have a msg soon just sorting some stuff out before i commit. Gotta compression test engine first before i begin all these mods! And i tried today and my guage is faulty.
If you bring it up here I can do it. I think the return flow from that cooler will be more expensive as more pipe is needed you also run a risk of crushing pipe on a speed bump. Unless you wanted it to look totally stock. I have a return flow cooler here it's yours for $50 I don't need it anymore. Otherwise I have a gtr cooler in good condition then I'll run the piping over your cam covers will look smick. Let me know what you want to do
I was thinking of something like this guy did http://www.skylinesaustralia.com/forums/topic/331717-r32-return-flow-intercooler-kit/ Looks nice and doesnt seem any lower than a normal Intercooler would be!
The whole point of getting the return flow is i don't want to cut a hole in anything. Want it to connect to the stock piping for the side mount intercooler. Everything will be sprayed black aas to attract less attention.
No I didnt trim the reo bar, but I had to use smallish pipe to clear everything, and used stainless as it was rubbing.
It was one hell of a 180 degree lobster. >_<
let me know what it costed him? lol im keen also, would like to know the details on how it fitted. also interested for my r32 gtst
I don't have any pic of the pipe that Scott made(absolute piece of metal art) but have a pic of what he had to deal with..it had been more easy if the FMIC was 60mm but i'm a bit slow at the brain and went over the top with 75(actually 82mm on a hybrid intercooler)and it's rubbing against the angle frame you can see in the pic...you can hear it when i start the car but while driving is ok(maybe need a bracket to hold it in place, but it's something for the future)
Feel free to give me a call, pm or sms if you would like some work done. Quality fabrication work and welding.
I can tow the car down here and you can drive it back ;)
  • 4 weeks later...
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
