Hi Guys.
Im after a bit of help in sourcing some 60mm (approx.) studs and nuts for my turbo manifold.
Basically have been told that the standard studs for the turbo flange are not long enough as my 35/40 has a spacer plate for clearance off engine and the nuts on it currently cant get a full lock.
Any ideas where I may be able to source some high tensile and also heat resistant studs from to suit the T3 flange.
Any help much appreciated.
https://www.sau.com.au/forums/topic/385388-exhaust-manifold-turbo-studs/
Im doing a similar thing, but fitting a gtx3076 and i got some studs from a local nuts and bolts shop, heaps around
Have you checked if your manifold is warped? cause mine is and will have to be machined, thought i should mention it in case you put yours on and its leaking.
Thanks for replies.
What is MTQ?
Also im kinda chasing specific shop names or "nuts and bolts" places who do the special studs to cope with the heat etc.
It seems lazy and well I guess it kind of is :) Dont play with cars much anymore just drive them
going through the same thing as we speak,
Just spoke to a guy, Brad from Atomic performance 02 86655889 they have what you need...
MTQ don't have anything special, just standard bolts with a squash locking nut.. if its a pretty standard setup and doesn't see lots of heat should be ok tho.. otherwise try Atomic
The ones I got from MTQ are high tensile, highly heat resistant.
high tensile has nothing to do with heat resistance.
but like I said, if its not a track car and doesn't see prolonged crazy high temps they will be fine..:thumbsup:
Edited by tricstar
+1
If you are changing them, you'd probably go the inconel ones regardless.
They are a bit more expensive but they will last the distance. It's not something you wanna do twice that's for sure
+1
I've just spent half an hour on google, with no joy, any idea where to get inconel bolts in australia ??
Thanks heaps for the info guys just wondering if anyone has got the studs of approx 60mm length?
Im just going off what I hae been told does this seem correct length im assuming factory is 40mm so makes sense.
Im looking for inconel bolts and lock nuts for my own 3071 spacer set up,iirc the studs need to be about 50 - 60 mm and the thread pitch is m10 x 1.5 I cannot seem to locate the studs anywhere, pm me if you know where I can source the studs as im tired of tightening the existing arp studs about once every few months
thanks in advance
Edited by aerofocker
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
