hey guys
just wanted to share sum pics of my new look r32 with u all.
i had sum free time to polish my engine since the RTA saw fit to cancel my licence.
didnt get to finish the final polishing stage but plan to do so soon.
also managed to get a set of advan siena generation II wheels
sooooooo cheap.
also goto aussie wheels n vote 4 me if u get a spare minute to register and also post ur own nissan up.
http://www.aussiewheels.com/profile/View.php?ID=256
thanks
https://www.sau.com.au/forums/topic/38541-my-new-look-r32/
MM2death"grrr why are rims so expensive. I'll just keep waiting until something pops up."
i have no idea, probably just coz they are a brand. hehe
anyways $4000 may not b exact, if sum1 knew the retail it would b great
rrrage: "why'd someone write that it was a "jap wannabe" ???"
i dunno, i dont bother replying to tossers.
i have never tried to upload pics here, any info how?
https://www.sau.com.au/forums/topic/38541-my-new-look-r32/#findComment-780745
very nice mate. just out of interest where'd you get the front bar / side skirts? (and how much did they set you back?)
CK you rice boi :) The side skirts looks like Nismo's to me -- there is a set at http://www.nismo.com.au/ for a R32 GT-R @ 450/pair, but no idea for a GTS-t.
LW.
https://www.sau.com.au/forums/topic/38541-my-new-look-r32/#findComment-781945
yeh the skirts are stock.
the front bar i bought in very bad shape from just jap had lil cracks everywhere and a massive 150mm crack on the side, so i got it cheap, at the time a friend of mine was working for a bodykit place, fixed it n reinforced it.
yada yada a total cost of $380 fitted inc paint!
saved bigtime,
cant afford the gtr bonnet n grill
the $1000 would b better spent on a fmic
https://www.sau.com.au/forums/topic/38541-my-new-look-r32/#findComment-782593
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
