As wide as you can afford the best quality tyres that fit them, how much power you got, only street, street and track?
Im running 245/45 17 dunlops on R34 GTT rims 7.5" on my boat for daily use, good tyres are a must, my 245 Dunlop Direzza Z1s out grip, out brake and out handle my old Nankang 265s by a mile, its also in the offset for fitment, my track rims are 9" wide with a 265 Dunlop Semi, they need at least 3 deg neg on the front and 2 deg neg on the rear to keep within the guards, which is fine for Semislicks at the track but would scrub out the inside of your tyres on the street.
https://www.sau.com.au/forums/topic/385808-wheels/#findComment-6153886
  • 4 weeks later...
I went 17x9+35 front and rear enkeis for my 33 fitted with 245/40/r17's all round car is lowered to just above legal height. Backs fit fine and could probably be getting into the +20 offset range before worring about rolling/scrubbing, the front however has failed me somewhat. i had to fit 8mm spacers for the rims to clear my brakes (rims are rpf1's, stock gtst brakes) and i get a bit of scrub on the edges if im cornering hard on a bumpy road, however they sit very nicely stance wise. Im hoping either a lower profile tyre or some 235's on the front will resolve this.
Hunting down tyres was a bit of a mission though. i wanted to get 255 or 265's on the rear but to do that the price was getting pretty painful, according to the blokes at the tyre shop the demand for wide 17' tyres is on the way down due to everyone getting big rims so the cost of them is going up, inversely the cost of bigger tyres is coming down and is cheaper then 17's now. If i were in your shoes with the knowledge i have now i would be looking into getting 18x8.5/9 +30 fronts and 18x9.5+30ish rears.
i dont have any good photos showing how they sit, just a couple snapped when i got them.
Edited by stompy
https://www.sau.com.au/forums/topic/385808-wheels/#findComment-6178056
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
