Hey guys,
Been thinking for a little while about selling my R33 to upgrade to something newer. She's a clean car, used as my daily and only has the basic of mods.
-133xxx km
-Silver in color
-Rego til January (will re-do if i still have it when it runs out)
-Turbo back exhaust (not sure what brand the dump pipe and cat are but the cat-back is x-force)
-turbo smart vee-port bfv
-18 inch rims (front tyres are 60-70% rear are 40-50)
-Full soundsystem consisting of: pioneer double din dvd receiver head deck, alpine type r splits in the front and type r coaxials in the rear, alpine vpower 600 watt 4 channel amp, kicker 350 watt mono block and dual kicker comp 10 subs.
Is a good clean car and runs perfectly fine. Always maintained with good quality oils and changed every 5000 km.
Cant upload any pics atm because im at work, but if anyone wants to give me a an email ill send some when i get home.
I would like to try and get $8500 with the soundsystem, and I will also chuck on 6 months rego if I can get that much. I am open to offers however and will take less without the soundsystem.
Contact me via email preferably [email protected] or on here.
ALSO
looking at possibly selling my bike if anyone is interested but id prefer to get rid of the car first. '91 model CBR250RR import. very clean bike, best learners bike out there if you ask me. goes well, rego til march, very good condition. 28xxx km. $4000 ono. reason for selling is to aid the situation above.
  • 3 weeks later...
no longer selling with soundsystem. $8000 with 6 months rego put on (rego expires on the 29th of this month). FIRM.
http:/IMG_1311.jpg
Edited by deadweight
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
