hey everyone was going to convert my gtst to a gtr front end but sold the car before I got around doing anything
I've got everything needed to do the conversion
gtr front bar with series 3 front lip (rare) and n1 vents license plate bracket ($850)
gtr front reo ($200)
aluminum gtr bonnet ( bonnet hinges and latch) ($650)
aluminum gtr guards with blinkers ($500)
gtr guard raisers ($200)
gtr front grill with badge ($150)
r33 gtr headlights with spacers ($200)
r33 gtr side skirts ($200)
would like to try and sell this as a whole but if I get interest I'll part it out. The prices in brackets are the part out prices. all panels are in white , front bar needs a respray and the lip could be patched up a bit.the front grill has a couple cracks but easily fixed. the lip is very rare and costs 1300 new from Nissan
looking around $2,200 for all of it.
postage can be oragnized www.transdirect.com.au
send me offers on parts you want and I'll let you know
if I choose to part out
location glen haven 2156
till: 0402362885
https://www.sau.com.au/forums/topic/385933-r33-gtr-front-end-conversion/
heyhey.. do you have any inner front splash guards?,, plastic inner guards?.. thanx.. nice good fcondition parts.. took me along time to get all hte gtr parts for the front in good condition :)
  • 1 year later...
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
