Hi guys,
I just changed my coil packs on my neo motor and just wondering if it is ok to leave the coil packs exposed (not putting back the long black rectangular cover panel), I have seen a lot of engine bays with exposed coil packs but my flatmate thinks there might be risks of water/ moisture getting in from the bonnet edges and splashing up from the road while driving. Are there many of you driving without this cover on and anyone see any probs??? The reason i wana leave it out is for easy quick maintenance swapping out the coils n spark plugs when the need arises.
https://www.sau.com.au/forums/topic/385934-rb25-engine-coil-pack-cover/
At the track it's a good idea to take it off to stop the coils from being cooked, but probably unnecessary to do with street driving. I know I leave my cover on when not at the track.
The nissan engineers know best . . .leave it on
Is that why neo coils invariably fail...since their engineers know best?
I have removed the coil pack on both cars and have driven that way for over 11yrs and 6 yrs with no issues after replacing the factory coil packs with splitfires. The heat seems to be a factor in killing them so why not take it off.
It doesn't really matter either way with normal driving, I've run my Neo without for over half a year, no issues. Some people say you can be defected for running without, blah blah. I suppose it's whatever you feel comfortable with.
Indeed, I've never heard any other engines have as many issues with the coils as the RBs... Oh well at least it's an easy swap.
Oh thanks guys then I guess it is ok to leave it open, in fact it seems like a better idea as you saying the heat kills coilpacks, but what about water/ moisture going in?? And possibly puddling up in the coil pack cavity as well?
The cover is vented thru slots on the timing belt cover and air flows thru them and out the back of the coil cover near the fire wall, , , beats crud dropping in the motor when you change spark plugs
Edited by StevenCJR31
+1 for leaving it off. keeps them cooler as well as actually keeping them free from moisture. the reason being that while moisture may get the them a bit easier, it can also get away from them easier. for example, if you degrease the engine, the cover doesn't seal that well and water will get in around the coils (know this from experience). with the cover offer, after a bit of driving around most of the water will be gone. leave the cover on and even after a few days the water will still be there because it can't evaporate easily (well it does, but it just stays under the cover as steam and then into water droplets and only a small amount of it actually gets vented - also know this from experience).
as for crud dropping into the motor when you change your plugs, if you are stupid enough to pull the plugs out with crud in the valley then you have no-one to blame but yourself. anyone with half a brain would clean it out before hand.
The cover is useless for keeping out moisture/dirt anyway, the holes for the bolts to go through leak and there is a big gap at the back as well. You need a substantial amount of water to cause any problems, you won't get anywhere near enough just splashing up from the road.
I've had mine off for about a year now, no problems.
i dont think they have done that bad a job. These cars are usually between 12-17 years old now. N for what they do (and how much more we get them to do) n how well they hold together is quiet an achievement.
[hyundais cant even seem last 10 years at 100hp out of a 2litre!]
its a part that breaks down over time. perhaps particularly in the aussie heat conditions (that they werent designed for).
N for what its worth iv run the cover off for 2 years with no probs (on spitfires). Tho got a custom vented one to go on so it looks a bit more kosher for the fuzz. (its all looking pretty modded under there now so dont want to give the boys an excuse if they arent happy with my style...)
Edited by jjman
Stock coils are still the best, they just don't last for 15 years, they're a perishable. If I had a choice between new OEM coils and Splitfires for the same price, I would go the OEM's.
Edited by Hanaldo
I got brand new OEM's for half the price of Splitfires ;)
u for real? whys that?
splitfires are known to be able to perform better, esp under higher stresses/hp.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
