I have everything except the modified rb30 block and the forged internals, Now my nismo dsah says 11000 rpm rev limiter on the taco.
I know even with a rb26 its to hard to reach that but with a Rb30 will it even touch the 9 or 10 rpm points?
No troll being serious here
With -5 turbos there is no need to rev past 8500 on a 2.6ltr
So on a 3ltr it would be somewhere under 8000rpm. Power & torque would be non-existent the higher you go as the turbos will simply run out of flow and drop majorly in boost - hence the revs are irrelevant given your turbo choice.
If you said a 1200hp+ turbo setup, then a different story.
so practically it will rev limit at 8000rpm.. do you think this is a good setup as i want power right through out the revs, 1 2 3 4 5 6 etc... My aim is a 10 sec street car high 10s are fine but I dont want too much lag. and im looking at the 400awkw mark.
Guest
