  • Replies 56
Will be late Jan or very early Feb, I'm back down to tas on the 5th of Feb and the stagea is now up for sale
Probably will be in the next 2 weeks so watch this space for datails!
somewhere between using bad fuel once and my turbo failied andinstalling a hypergear/walbro/450cc injectors, nistune and taking too long to get booked in at a tuner, them delaying it an extra week because they couldnt get my front shaft out (they charged me an hours labour to not get it out)(took me 10 mins and i dont even have a jack), it was tuned st 306hp, 20 psi at 4000rpm dropping to 14psi at 7000rpm. on the way home from the tune i had a strange noise (i now think it was audible knock) and repeated check engine lights so pulled over about 10 mins after picking it, (pulled over as soon as the light came on) rang the tuner and he never returned my call. it never ran properly after that, did a compression test after trying all sorts of tests and came back at 96 167 167 167 167 167, tipped in some oil and came up to 130, i found 4 big problems once i had it apart, broken engine mount, cracked piston, valve about to drop, headgasket borderline blown, so yeah been a few months driving my mums camry.
Ok, got my car back (albeit with my optima battery completely f$%#@*d, and damn battery world not honoring the warranty.... So, should get a new batt today... I am still tentatively in, but my car will be going into the panel shop very soon to (finally after 3 years) get the roof rail replacement kit fitted!
I'll keep an eye on the dates, and try to make sure I have the Stag on the road for this meet... :)
Someone will have to take over this one for me, I'm heading to the uk tmrw for a funeral
Then I'm off to tassie 5 days after I return
Hopefully someone can take over and finish this so you guys get a meet out of it
Cheers, tom
Sorry to hear the bad news Tom.
I'll run a few ideas up the flagpole & see who salutes.
So everyone, either the weekend of 21/22 or 28/29. Can a few people vote for a day?
I would prefer a Saturday, but traditionally these things are held on a Sunday due to work/sport comittments etc, so maybe the first few in agreement can set the date & the rest of us will have go with it. In any case there's no way everyone will be able to make it no matter what date is set.
I've got a few ideas for the route but would appreciate someone reminding me of the usual GC meet point/s.
Cheers, Leon.
What's a guy got to do to generate some interest? Free drinks at lunch?
OK, Sunday 22nd of January, yes, just over a week away (unless a significant number of people actually speak up for a different date).
Route TBC.
sounds pretty good to me. Usual meet spot I we use is Coomera BP, but depends on where you want to go.... Mudgeeraba Shell is another good spot (and it's only 2 min from my place!!)
The route for Sunday is the reverse of a cruise from 2009. I'll post a route map in the next day or so, but essentially it is this:
South down Pacific Motorway with pickups along the way, Locations & times to be confirmed.
Exit around Elanora & head up Tomewin Mountain Rd
Over the top of the mountain & down into Murwillumbah.
Out thru Crystal Creek & up past Natural bridge & Numinbah Valley.
Back onto the motorway again at Nerang & head for home (or lunch?).
We'll have some stops along the way, so if you have any suggestions/locations for lunch please let us know.
Thanks to Micah for his input & especially for confirming the roads are OK to drive on as of a few weeks ago.
Looks like the usual apologies are coming in thick & fast, lol. Happens every cruise.
Hey Josh, I hope you can make it as I don't want to be the only M35 there.
For everyone else, it doesn't matter if your Stag is clean or dirty, modified or standard, straight or dinged - I'd like to encourage everyone to take a few hours to meet up & have a drive.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
