What is the best way to cut a hole near the washer bottle to run some IC piping up through?
Also how do you know for sure where to cut it?
It is for a Plazmaman plenum and Plazmaman IC piping on an ERC33.
https://www.sau.com.au/forums/topic/386626-cutting-hole-for-ic-piping/
Apparently cutting holes in the walls around washer bottle, or under battery tray in those "structural" areas are illegal and turn your car into a write off? I wanted to cut a small hole under the battery tray in that side wall where the tow hook is in my R32 to run piping through for a front facing plenum but a tuner / mechanic scared me off the idea... So im not so sure any more about cutting random holes
We used to get them all the time and knock them back on RWC's for it. You can get the cut approved by an engineer, and its easire than you think. Just have a chat to your nearest engineer and see what he says, it usually just involves stitching some flat plate around the area to give its stiffness back. Also, remember, measure twice, cut once and try to paint and line the exposed area to stop the steel rubbibg through your IC pipework and your car rusting.
what kind of place has an engineer? Are they special mechanics? We just call them Cert shops in NZ where a Low Volume Vehicle Certifier checks over your car and its modifications, eg suspension, exhaust, air bag suspension etc etc and if its at legal height and not a dodgy install he certifies it and puts a fancy little plate on your fire wall with the mods engraved. Is it the same here? I need to find out the ins and outs of this sorta stuff, its so much stricter in this country down.gif Cant build a 300kw car on your learners plates and legally drive it to school here
yep, in aus they have automotive gingerbeers, or certified inspection officers. You get it inspected, he signs it off, gives you a sheet of paper and if the mod warrants it, a blue plate.(in QLD anyway, unsure of other states)
  • 4 weeks later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
