Having some trouble with my 1990 r32 gtst Sometimes when I drive it won't rev over 2000 rpm it revs to 2000 and then drops to 1500 and bounces between that at wide open throttle like a rev limiter if I take off in a higher gear then force it into lower gear n get the revs over 2000 rpm then it's fine to drive until it drops back under 2 grand, have tried a couple air flow meters and swapped ecu's any help is appreciated, thinking maybe TPS or cas
https://www.sau.com.au/forums/topic/386864-rb20-proplem-please-help/
try setting your fuel pump to full pressure all the time. i had a problematic dropping resistor in my stag that wasnt letting enough fuel through, hence the stalling when more air is introduced.
i think on 32's its the silver aluminium box thats bolted to the left hand strutt tower. try simply disconnecting the plug
Down in tassie. It doesnt stall when more air is introduced it cuts the revs like an ignition fault not fuel but I will try the fuel pressure thing. Have had a look at wiring e.g wiggle test and terminal tension when fault occurs, have tried known good afm, I think it's more sensor related, it happens after you drive it get it hot turn the car off for a while and then re-start it like a sensor getting hot and
Playing up
Playing up
  • 3 weeks later...
So it looks like the problem is after fitting a r33 turbo things are a bit hotter around the left hand side strut tower, this has caused the insulation to melt off the loom, I pulled the rest of the isolation and inspected all the wiring no faults, the problem is when the loom get really hot it gets a high resistance in the wiring I believe (getting very hot) so re insulated and relocated wiring loom and also applied some heat shield seems to be all good!
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
