and as a heads up a cheap supercheap cannon as a rear muffler are pointless, barely reduces noise, will alter the exhaust note to be more "raspy" which unless your a Honda lover is usually undesirable lol, and if you go to big ie anything bigger than a 4" tip people will laugh at you.
just my opinion its your car man build it how u like, still keen to see a video of the cars exhaust :)
  • Replies 51
sorry dude i didn't realise it already had a catback. resonators actully help an exhaust more than people realise as they reduce resonance wich helps a lot with the horrible drown skylines seem to have at around 2000 rpm.
If I put a Varex muffler on this which bypases the noise through smaller holes packed with god knows what to quiten it down, would I still be able to take them out?, I got one put in and I hardly heard a difference
most mufflers are packed with fiberglass, i can imagine the varex one would be to different. Personally i have no experience with the varex kits, but I've herd cars with them and when the internal valve is closed i wasn't a fan of the sound, deffinatly quiter but.
I would rather have an exhaust that has a nice note and volume all the time, rather than having something loud and raspy when open and muffeled to high hello when closed. I'm sure there'd be a thread on varex products on here somewhere.
The only reason I look at this option is because I have been told by transport my car is too loud before which is why the stocks on it atm so I thought that would be a good idea and i've heard you can get a good sound from them when opened up
Yeah definate, well My muffler dealer (Local Muffler dealer) said he could install one (A large some of money) and it would be legal. They also install them onto new R8's and XR8's. So i'd hope they're.
i think s1 had is as an option and so they all had the fuse locations. if there is an alloy box at the back of the engine bay with brake lines going into it then you have abs.
you can see it here behind the power steering reseviour
Se the wire connection on the end of the pipe from the CAI, the grey and the brown plug going into the black box, what is that for?
home made varex still isn't legal. any muffler with some form of variable restrictor has to be tested at it's loudest, which is why the varex aren't legal.
moral of the story: don't be another one of those dopey P plate skyline owners driving around with a stupidly loud exhuast that sounds like arse (to everyone but you) giving the skyline community a bad name.
can't wait for school holidays to be over.........
yer i didn't think they were legal, and hey hey hey I'm on my ps and my na skyline isnt that.... wait a minute yer its pretty loud, but on the down side i lose kebab points for not having a cannon lol.
Eh gay, it doesn't have any ABS, why would there be something in place of the 30Amp slots in the fuse box then?
My NA has fuses for ABS, ATTESSA & HICAS, none of which it has.
If you want a Varex or something similar try to source a GTS25 Type S factory exhaust. Rear muffler has a butterfly in it. You could always try your luck with the Varex and if cop pulls you up say your car is a Type S and so came with an exhaust with a butterfly as standard.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
