changed to the united oil united 1 5w50 from ash(kingscorp) It's fully synth and so far it has been great I now have good oil pressure on cold starts (70psi approx) and on idle it now is about 40psi instead of 25. So far I highly rate this oil and for half the price of royal purple etc I don't think I'll ever look back. If ash is still doing a bulk deal I will buying in bulk in the very near future.
Once again thanks ash
https://www.sau.com.au/forums/topic/387130-united-oils/
  • 2 years later...
Benchmark for oil pressure is ~10psi per 1000rpm, a little higher at idle. 25psi is a much more sensible idle pressure than 40, and shows that the 5W-50 is too thick. What viscosity was giving you 25psi? I like 0W-40 for the rb26dett and vq25det.
https://www.sau.com.au/forums/topic/387130-united-oils/#findComment-7424592
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
