This probably has happened before to someone and hopefully someone can point me in the right direction.
Last month I got my Power FC installed and car tuned at Ultimate. When it was tuned the guys noticed the engine light flashing, and tuned it for the knock the Power FC was telling them. Now under slight load, the light flickers, but no I can't hear any sign of knock in the engine.
They did suggest to run a few bottles of injection cleaner through the system, but that hasn't made any difference.
I also did some research but still can't put any one finger on a problem. So any advice would be appreciated on how to fix it. They did offer a retune at no extra cost, but I want this problem fixed before it goes back.
Cheers guys.
https://www.sau.com.au/forums/topic/387982-something-very-confusing/
what knock is the powerfc showing on the hand controller? 60+ will flash the check engine light
is the engine water temp getting to 100+? this will also bring the check engine light on.
does your exhaust still have the cat temp sensor? from memory in the R32 this detecting the exhaust is too hot will turn on the check engine light.
I have GReedy temp gauges for front and rear of the engine and it does go above 100 degrees and I will have to check the exhaust. But the temp on the stock gauge does read normal. And have never had the knock go above 60.
The car does run 98 all the time.
And the tune was about $560 from memory, but that was also them installing the power fc and boost controller.
The tune was done a month ago.
I know the knock it has isn't as good as it should be, but finding out whats wrong with it is extremely hard as noone can put a finger on it, or point me in the right direction.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
