This probably has happened before to someone and hopefully someone can point me in the right direction.
Last month I got my Power FC installed and car tuned at Ultimate. When it was tuned the guys noticed the engine light flashing, and tuned it for the knock the Power FC was telling them. Now under slight load, the light flickers, but no I can't hear any sign of knock in the engine.
They did suggest to run a few bottles of injection cleaner through the system, but that hasn't made any difference.
I also did some research but still can't put any one finger on a problem. So any advice would be appreciated on how to fix it. They did offer a retune at no extra cost, but I want this problem fixed before it goes back.
Cheers guys.
https://www.sau.com.au/forums/topic/387982-something-very-confusing/
what knock is the powerfc showing on the hand controller? 60+ will flash the check engine light
is the engine water temp getting to 100+? this will also bring the check engine light on.
does your exhaust still have the cat temp sensor? from memory in the R32 this detecting the exhaust is too hot will turn on the check engine light.
I have GReedy temp gauges for front and rear of the engine and it does go above 100 degrees and I will have to check the exhaust. But the temp on the stock gauge does read normal. And have never had the knock go above 60.
The car does run 98 all the time.
And the tune was about $560 from memory, but that was also them installing the power fc and boost controller.
The tune was done a month ago.
I know the knock it has isn't as good as it should be, but finding out whats wrong with it is extremely hard as noone can put a finger on it, or point me in the right direction.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
