Anyone got defected at Chapel st last night?
  • Replies 90
major defects gets you a $165 fine, BOV gets you a $500 fine,
EPA will also fine you for having ANY kind of boost control be it hydraulic, pnuematic or electronic.
i received a minor defect for the catch can, steering wheel
Chr1st, they can really defect you $500 for having an atmo BOV??? Im betting being on NSW plates aint going to help me... if i get pulled over my car will never get back on the road :(
i got done once and one of them blueshirt freaks told me to buy a commodore wagon, he says "why cant you buy a car like this (pointing to the wagon) we will leave you alone anytime, anywhere, anyday".
Get a Stagea then, they won't know the difference :), but yes that attitude from the police is highly discriminating.
I was down Chapel last night and saw at least 4 WRX's get Defected, a few commodores [not wagons though LOL], a supra, celica, and a few 200sx's also - mainly S14. I think the whole squad [of police] was there again including RIOT van - wtf for? I don't know.
Guest INASNT
if a cop ever told me that i would tell them i would rather catch the bus than drive 1 of those :)
Guest RedLineGTR
The people I see defected on chapel street "ATM" I have no pity for, since this blitz has been on for the past couple of weeks, I reckon that anyone that goes down there at this time with some sort of modifications like exhaust etc and keeps cruising around either have a very low IQ or are just dumb sh1ts that deserve to get a defect. Everyone knows atm that chapel is not the place to drive through with a modified car or a unroadworthy car...but I guess some people don’t. My 2 Cents
Cheers Rob
Guest INASNT
what happends if you drive a stock gtr cops cant do shit.
cops dont know shit from clay, and they eat both every night of the week. :rant:
its 'in their opinion' remember so a person with the brain capacity of a baboon can thing your stock gtr is defectable
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
