There's a lot of people running around saying "I have a Type S R32 GTSt" or "I have an M Spec GTS". Bollocks n boulderdash I say... here's the definitive guide on R32 Model classifications.
Production Dates
R32's were poduced from May 1989 (although they were only released to public a while later) till mid 1994. A minor change was made in the structure of the car in August 1991.
Classification
[b]Two Door Coupe[/b]
[i]Vehicle Code	Engine Code	Model name[/i]
HR32  RB20DE  GTS
   GTS Type J
   GTS V selection
HCR32  RB20DE  GTS Type S
 RB20DET  GTSt
   GTSt Type M
HNR32  RB20DET  GTS4
ECR32  RB25DE  GTS25 Type S
BNR32  RB26DETT	GTR
   GTR V-Spec
   GTR V-Spec 2
   GTR Nismo
[b]Four Door Sedan[/b]
FR32  CA18i  GXi
   GXi Type X
HR32    RB20E  GTE
   GTE Type X
   GTE Type X-G
 RB20DE  GTS
   GTS "Urban Load"
   GTS Type X
 RB20DET  GTSt (Only cars made before Aug 1991)
   GTSt TypeM
HNR32  RB20DET  GTS4
 RB26DE  Auctech Version
ER32  RB25DE  GTS25 Type X
ECR32  RB25DE  GTS25 Type X-G
Decoding the Vehicle Code
Another common misconception is that HCR32 means the same thing as HR32. It's actually a different car, this table should help you decypher the Vehicle Code.
The 1st character indicates the Displacement Volume
B = 2600cc(2568cc,RB26DETT)
E = 2500cc(2498cc,RB25DE)
H = 2000cc(1998cc,RB20DET,RB20DE,RB20E)
F = 1800cc(1809cc,CA18i)
The 2nd Character indicates the Drivetrain Options
C = HICAS included on model
N = ATTESA (GT-R, GTS-4, Autech)
The rest of the characters are the Model Code (ie R32)
2 Door Coupe Specifications (non GTR)
Transmission	5 Gears or Full Range Electronic Control Auto with Overdrive (E-AT) 3 Gears
Exterior Dimensions
Length  4530 mm
Height  1695 mm
Width  1325 mm
Interior Dimensions
Length  1805 mm
Height  1400 mm
Width  1090 mm
Wheelbase	2615 mm
Front Tread	1460 mm
Rear Tread	1460 mm
Ground Clearance	145 mm
Vehicle weight  1260 kg (Automatic 1280 kg)
Vehicle gross weight	1595 kg (Automatic 1615 kg)
Passenger Capacity	5 Adults (Although this is very questionable :D)
Performance
Minimum Turning Radius	5.2 m
Fuel Consumption	9.5 km/l (Automatic 8.0 km/l) *
* Figures based on Japanese Ministry of Transport tests
Standard Equipment
Clutch 	 Hydraulic Pressure Operated (Automatic: Liquid type torque conversion)
Steering  Rack & Pinon type (Rear wheels controlled optionally by Super HICAS)
Suspension  Front and back independent suspension multi-link type
Brake 	 Ventilated disk brakes front and back
Handbrake  Mechanical cable type (2 wheel braking )
Front and rear tyres	205/55R16 88V
https://www.sau.com.au/forums/topic/38809-r32-model-name-classification-guide/
I'd assume so, I haven't got those stats, however, here's something I do have...
Differences between Pre Aug 1991 R32's and Post Aug 1991 R32s
Front indicator lenses
S1 - Clear
S2 - Orange (GTR ones are different to these)
Front bumper
S2 - New "Aero" Design
Side GT emblem
S1 - Silver
S2 - Colouring (Type M and GTR - Red, GTS and GTS4 - Blue, GTE - Green)
Rear emblem (4 door)
S1 - The 'SKYLINE' Emblem is small.
S2 - 'SKYLINE' is larger and more spaced out.
Tail lights (4 door)
S1 - Flat surface on lights
S2 - Some areas are slightly recessed
Center console
S1 - Smooth Plastic
S2 - Textured (matches the dashboard)
Gauge colour
S1 - Dark blue
S2 - A blackish grey
Interior trim
S1 - Cloth
S2 - Velour
Timing belt cover
S1 - Letters "RB20" on the Cover
S2 - Blank surface
Side doors
S2 - Additional Side intrusion bar in Door
Projector headlight
S1 - Low:H3C(55W) High:H3(85W)
S2 - Illumination angle widened, Low:H1(55W), Hi:H3(85W)
Ignition coil
S1 - Carbon contact point
S2 - Spring contact point
Front Bumper
S1 - Has a plastic mesh on the bottom right and left ducts
S2 - No mesh due to different shape of ducts.
That would be you're date of registration. Unless your previous owner that bought a limited edition 50 only V Spec 2's that were made in 1994. In which case your car's a collectors edition in Japan.
I haven't put much GTR info up yet, mostly concerned with lower classes for now. I'm still compiling GTR data.
Hi Funky,
under '2 door coupe specifications' you have a weight listed as 1260kg for manual and fuel consumption as 9.5kml - which model is this? I take it's probably not the gts4. Do you have any specs for the gts4?
just to confirm what i wrote earlier, the build date of my car was in 09/94, i know this cause in the engine bay where is says build date on the plate it has 09/94 pushed into the metal.
if you have any objections to this i can take a picture of it for you.
Yup, you get the VIN number, and you put it in FAST, which is the Nissan dealer database for all cars manufactured. You'd be interested in FAST Japan (since it was manufactured in Japan). I've got access to FAST UK and FAST Japan so if you wanna PM me your VIN number (not the aussie compliance one, the one on your blue plaque on your firewall) I can give you full specs for your car, from factory options to year of manufacture. I'm currently trying to reverse engineer the database in fast so that I can make the data on skylines accessible through the internet, it would be a very useful tool.
I've just created a new thread in this section called R32 Chronological History which should help some of you guys out.
There's a bit of mixed info about test data. I'm still in the process of translating the original brochures (just got around to finishing R33 Series 1's). Once that is done I should have manufacturer data on every single model. (including factory power graphs etc).
Mind you it costs money to get original brochures, esp the special editions (cept the V Selection 2 GTS hehe coz I got one of those n it came in my car).
I've registed the domain japimports.info, and hopefully I can put all this stuff in a proper layout with the hundreds of scanned images I've got.
  • 4 weeks later...
hey funky monnkey
i was wondering if you could help me with a question i've been thinking about and with little info that i've been able to find have been thinking about it for a while now. Anyway i was just wondering what models of the R32s come with realwheel drive and which with four wheeldrive. Also with the four wheel drive versions are you able to pick between RWD and fourWD.
Anyhelp would be much aprreciated thanx
hey funky monnkey
The r32 gts-4 and gtr's are the only four wheel drive vehicles, they are not always 4 wheel drive due to how the attessa system and how it works, torque split setup. I beleive that to put a 4 wheel r32 into rear wheel drive it's as simple as removing a fuse.
GTS-4 has an rb20det withe super HICAS (all wheel stearing) and ATESSA (4 wheel drive system)
GTR is has the RB26dett and hicas + atessa.
GTS-4's are not very common, but they more are becoming to the road. The gts-4 was the second most expensive vehicle out of r32 to range when sold origninal in Japan.
GTS-t, GTS, GXi ,GTE and GTS25 are all rear wheel
Hiya Funky M! A world of knowledge,you are-it's refreshing to see someone has the facts....What made the V-Spec II stand out from a 'Spec I?I was also led to believe there was more than 50 of them.Can you still work out a vehicles' history off it's numbers?I'd love to know more about mine(R32 GTR),that's all...Cheers,J.
i have a vspec 1, and they made 1453 of these in 1993. Vspec 2 were made in 1994 amd there is a total of 1300.
Difference i was told was that the suspension setup for the vspec 2 was for 'le mans' racing, apart from vspec 1 road setup.
Apart from that no differnce apart from sticker at back that say v-specII instead of v-spec
its quite easy, you get the vehicle Chassis number (not the compliance number) and plug it into FAST, which is the nissan system that looks up spare part codes given a vehicles identification. Hence hy Nissan spare part dealers can look it up.
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
