The NRMA guy unpluged the AFM and the car start up and stayed on
zei20l
unplug the AFM and try to start the car. if it starts, buy a new AFM. if it doesnt start, its something else. might be one of the CAS's
Do you think I need a Fuel Pump or a new AFM?
https://www.sau.com.au/forums/topic/388126-car-just-stop/#findComment-6187414
its the AFM!
mine has died a few times, so have other peoples that i know. its around $220-320 depending if you get it trade or retail.
sorry i dont have the part number, i dont think mines the same as the other VQ engines
https://www.sau.com.au/forums/topic/388126-car-just-stop/#findComment-6187424
Could be a dirty intake manifold. When I first bought my car, I had the same issue. It happens when the engine is warm, starts up then shuts down. I took it back to the dealer the same day I bought it, they took out the manifold and gave it a real clean. Never had a problem after that.
https://www.sau.com.au/forums/topic/388126-car-just-stop/#findComment-6187510
Nissan will have an afm but it wont be cheap. You only need the sensor not the tube it sits in. You can try from the US once you have the p/n, it will be half the price.
The intake or more specifically the throttle can cause the car to stall if its too dirty but if you unplug the AFM and it runs then theres a good chance it isn't the throttle.
https://www.sau.com.au/forums/topic/388126-car-just-stop/#findComment-6187688
cleaning it will do nothing, ive tried this several times.
just buy a new one from nissan.......
its 5 mins to install, so please DONT pay a mechanic to install it
the good thing is you can still drive the car without the AFM connected
https://www.sau.com.au/forums/topic/388126-car-just-stop/#findComment-6189484
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
