I found and run the test, but unfortunately did not show up anything, does anyone know where the water control valve is, i presume its an electric solenoid type hidden away somewhere??
Climate Control Diagnostics R32 and R33
The climate control has a diagnostic mode.
Enter the diagnostic mode by pressing the OFF button for five seconds within ten seconds of
turning the ignition on.
Sensor check
Sensor check is selected by pressing HOT switch (the red triangle) while in diagnostic mode.
The microcomputer detects whether each sensor input signal is within correct parameters. The
results are displayed on the screen.
If normal, a "20" is displayed.
If abnormal the failed sensor number is displayed. The sensor numbers are as follows:
20 - all is normal
21 - outside air sensor
22 - Inside air sensor
23 - Water temperature sensor
24 - Intake temperature sensor
25 - Sunload sensor (small sensor on the left hand side of the dashboard near the windscreen)
26 - PBR
27 - Refrigerant temperature sensor
This should tell you if any of your sensors are faulty.
Mode door position check
(This is probably not the cause of your problems but it is a nifty self check to play with).
While in Sensor check, depress the HOT button again. This will operate the the mode door
actuator, and checks the whether the position detection switch is operating. Again the results
are displayed on the display.
If normal, a "30" is displayed.
If abnormal the number of the faulty mode is displayed as follows:
30: Normal
31: VENT
32: B/L (Bi level)
34: FOOT
35: DEFROST/FOOT
36: DEFROST
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-62873
Originally posted by inark
its 1am... but im going outside to have a fiddle with it just cause that looks like fun haha
lol yea i like fiddling at 1 am too...
sorry i cant help u there jethead. i did the test and 25 - Sunload sensor seems to be faulty....bo my question is, what does it do, and is it important???
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-62925
You should have got error 25 (Sunload Sensor).
Word of caution, even in shade on a bright sunnny day you can get error 25.
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-63194
Originally posted by skyline33
leon,
I thought you fixed it
errr the guy that sold it 2 me did....but then a few dayz ago it made that sound again.... :) I don't wanna go back 2 him and get it fixed again..u said u know someone that can fix those stuff right? Need some help man
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-63498
yer..it was the gate thingy that heat your windowz when it goez foggy....it wasn't moving properly.....it still workz though, just makez that annoying sound..... And I dunno y but I get hot feet instead of cold feet...heater is on no matter I turn it off :) weird shit....
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-63503
On the righthand side of the gearbox tunnel Adjacent to your left foot is an servo/motor mechanism that sequences the buterflies and water valve via a push/pull cable. This mechanism was stuck, gave a bit of a helping hand and away it went, all is fine now. Fault code 26 then dissapeared, left with Sunload sensor fail but who cares...Ive got heat now..
Can someone tell how to identify/find the Sunload sensor????
https://www.sau.com.au/forums/topic/3883-no-heat/#findComment-63513
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
