Set of 4 17" 5X114.3 Panasport G7 polished wheels powder coated in champagne. These wheels are hard to come by, they have a staggered width of 8.5" fronts and 9.5" rears. Come with Federal 595 S tyres, all above 80% tread, 215/40/17 (front) 225/45/17 (rear). Offset is unknown, but assumed +30
No wheel nuts provided.
These wheels suit any 5 stud silvia, skyline, supra etc
$1500 ONO
Contact via pm or 0432719775
Edited by Jesss14
Not sure sorry dude, haven't even had time to test fit on mine
I guess google similar spec wheels and see what they look like on 34s. Offset is around +30
Edited by Jesss14
  • 3 weeks later...
PM sent hy
Price drop $1400. Dished 3 piece jap wheels that you will not see around on other cars!!!
Edited by Jesss14
  • 4 weeks later...
Bit misleading to be selling damaged wheels - and not informing the buyers
- Two of the wheels are buckled
- Both of the buckled wheels have flat spots/bent lips
- One has a large crack
Bit hard "not to know" they were in this condition if you own them.
Buyer Beware
Jess - Getting your boyfriend (or whomever) to ring people and make personal threats against people as the truth has come out about what you are selling, it unacceptable.
In 10 years, only one other time has there been incidents of (childish) personal threats. SAU will not tolerate a attitude like that.
You are now banned.
have you seen them in person? the last time i saw them they were fine?
Not sure what your definition is, pics will tell the story.
All the wheels have marks from bolt on spacers where someone has failed to properly cut down the original studs so that they have been sticking out further than the spacer preventing the wheels from being tightened properly
Centre hub gouges
Crack #1
Crack #2, pic 1
Crack #2, pic 2
Buckle #1
Hotspot #1
Flat spot #1
Flat spot #1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
